Fuel tank capacity and cold weather
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jmpenn, May 27, 2006.
  1. jmpenn
    jmpenn New Member
    110
    Rockaway, NJ
    "The fuel tank capacity is decreased at low ambient temperature. (decreased by about 5 L (1.3 gal., 1.1 Imp.gal.) at -10C (14F).)"
    I guess that puts that question to rest. When the temperature drops to freezing, your gas tank holds about a gallon less.
  2. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    a gallon- or more.
    99% of us will never get the whole 11.9 gallons in to begin with even in nice weather.
    it's a quirk, you get used to it.
  3. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
  4. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi All,
    Yea, I had a direct observation of this. Based on comments about 2006's running out of gas, I decided to fill up right after dropping down to one bar. The first time I did this the one bar showed about 3/4 s the way up to work at 20 F. The tank filled up with 8.2 gallons. The next time the tank dropped to 1 bar I was 3/4 s the way home from work, after a sunny day in the low 50's. The car was sitting out on the blacktop all day, too. The car took 9.3 gallons to fill up.
    My Car really is a 2006 Prius. Ignore the mistake in the header to the left.
  5. Rick Grahn
    Rick Grahn New Member
    285
    Illinois
    <div class='quotetop'>QUOTE(Whitestar @ May 27 2006, 05:35 PM) [snapback]261859[/snapback]</div>
    Here are a couple of question for you all...
    If you store your vehicle in a heated garage, and fill up within, say, two mins of leaving that heated garage...
    1. Is the tank going to accept the smaller amount or larger?
    2. If the larger/warm weather amount is possible, will some of the fuel be "pushed" out the filler tube overflow if you then drive in cold weather and tank "cools?"
    Just wondering.
    Rick
