Traction Battery Fan maintenance
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Jorlan, Jul 19, 2016.
  1. Jorlan
    Jorlan Junior Member
    35
    27
    Hi My I got 2016 PRIUS back in February and is now close to hitting 20,000 miles...I have been bringing it to the dealer for maintenance until I hit 25,000 miles when the Toyota care expires then I will just do maintenance myself...
    When is the fan for the traction battery due for regular cleaning and filter change?
    GaryD1 likes this.
  2. kithmo
    kithmo Couch Potato
    2,404
    2,774
    47
    South Yorkshire, UK
    Here in the UK, it's not actually on any of the service schedules, but I'll probably check it myself at 20k miles. If it's still clean then I'll check it again at 40k.
    RCO and Mendel Leisk like this.
  3. bisco
    51,043
    no need to bother unless you carry furry shedding animals regularly. other than that, no one has ever found anything that would inhibit cooling.
  4. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Thank you bisco. Those are the "gems" of information that I like to see from you Prius veterans.
    RCO and bisco like this.
  5. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    Where's it located and how do you access it?
  6. Jorlan
    35
    27
    Now I'm curious how you access it...I took the bottom seat off and I cant seem to access it...And that plastic screw on the actual vent cover isn't it either...The manual states call the dealer if it needs replacement...but its just a filter if anything...it cant be that hard to replace
  7. Mendel Leisk
    40,498
    If you get down to it please post some pictures.
    It's not on the Toyota schedule. For peace of mind I would check it at least once, just to satisfy yourself what is or isn't going on with it, say around the aforementioned 20,000 miles. It shouldn't be terrifically difficult. Keep in mind you likely only have to get to it, not pull it completely out, to clean it.
    RCO likes this.
  8. Coast Cruiser
    2,267
    2,571
    These are the kind of things that Auto Manufactures do that bug the heck out of me. Why not just put a simple, easily accessible filter just inside the vent cover!!!? Something that we owners can change (like the cabin filter behind the glove box--easy).
    RCO likes this.
  9. Rebound
    Rebound Senior Member
    3,972
    2,626
    Portland, OR
    I took mine apart after four years and it was unnecessary. Those fans don't get clogged unless there's a lot of hair getting sucked in, namely pet hair.
    RCO likes this.
