How to place greenhybrid signature in Prius chat
Discussion in 'PriusChat Website Questions' started by cary1952, May 28, 2006.
  1. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    I know its been told before, but i cant find it, so any help would be appreciated.
    Cary
  2. AnOldHouse
    AnOldHouse Member
    677
    Middlesex County, Connecticut
    <div class='quotetop'>QUOTE(cary1952 @ May 28 2006, 09:00 AM) [snapback]262006[/snapback]</div>
    User the following for a clickable signature:
    (url=http://www.greenhybrid.com/compare/mileage/car/XXXX.html)(img)http://www.greenhybrid.com/compare/mileage/car/XXXX/signature.png(/img)(/url)
    Change the parenthasis to square brackets and replace the 2 instances of XXXX above with the greenhybrid.com ID number for your car found in the link at the very bottom of the "View My Vehicles" page below the sample of the greenhybrid.com signature.
  3. EricGo
    EricGo New Member
    1,805
    Albuquerque, NM (SouthWest US)
    If you want a link to your mileage chart at greenhybrid, e.g.,
    AnOldHouses' Fuel Economy
    Go to your mileage chart and copy the URL,
    Then use the built-in linker in the composition bar to edit your signature for PC. It is the little icon of a globe with a metal link. You will be prompted for the link -- just paste; and then type whatever text you want to label the link.
  4. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    <div class='quotetop'>QUOTE(cary1952 @ May 28 2006, 08:00 AM) [snapback]262006[/snapback]</div>
    Thanks. I got it to work!
  5. AnOldHouse
    AnOldHouse Member
    677
    <div class='quotetop'>QUOTE(cary1952 @ May 28 2006, 11:23 AM) [snapback]262031[/snapback]</div>
    Good Job! Now watch as that MPG average climbs up with warmer weather in South Dakota!
  6. singingtiger
    singingtiger New Member
    59
    Boulder, Colorado
    I also like the Green Hybrid graphic link. So this is my test post
  7. AnOldHouse
    AnOldHouse Member
    677
    <div class='quotetop'>QUOTE(singingtiger @ May 28 2006, 10:29 PM) [snapback]262202[/snapback]</div>
    Woohoo! Look at those MPG's!
  8. JSH
    JSH Senior Member
    2,605
    140
    PDX
    Testing #2?
  9. Wildkow
    Wildkow New Member
    5,270
    37
    36
    <div class='quotetop'>QUOTE(jhinton @ Feb 21 2007, 09:13 AM) [snapback]393980[/snapback]</div>
    Mine won't work I get an error about having a dynamic link within a image. or this . . . You are not allowed to use that image extension on this board. A valid format is: http://www.domain.com/picture.gif, an invalid format is: http://www.domain.com/picture.one.gif Can anyone help?
    Wildkow
  10. Proco
    Proco Senior Member
    2,570
    172
    28
    The Beautiful NJ Shore
    <div class='quotetop'>QUOTE(Wildkow @ Feb 22 2007, 10:12 AM) [snapback]394480[/snapback]</div>
    Your GreenHybrid link is coming through just fine.
    Your Folding@Home stats, on the other hand ...
  11. Wildkow
    Wildkow New Member
    5,270
    37
    36
    <div class='quotetop'>QUOTE(Proco @ Feb 22 2007, 07:40 AM) [snapback]394499[/snapback]</div>
    Sucks. . . I know, been working on that for awhile and still can't get it to show in the sig like it should.
    Wildkow
  12. Danny
    Danny Admin/Founder
    7,093
    2,117
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Does this code not work?
    Code:
    [img]http://folding.extremeoverclocking.com/sigs/sigimage.php/t=304[/img]
  13. Wildkow
    Wildkow New Member
    5,270
    37
    36
    <div class='quotetop'>QUOTE(Danny @ Feb 22 2007, 06:42 PM) [snapback]394978[/snapback]</div>
    No it tells me that you can't put a dynamic link in a image. or it says You are not allowed to use that image extension on this board. A valid format is: http://www.domain.com/picture.gif, an invalid format is: http://www.domain.com/picture.one.gif
    Wildkow
  14. jpajot
    jpajot New Member
    <div class='quotetop'>QUOTE(AnOldHouse @ May 28 2006, 09:21 AM) [snapback]262015[/snapback]</div>
    Test
