Possible Pricing Release
Discussion in 'Prime Main Forum (2017-2022)' started by Tideland Prius, Jun 25, 2016.
  1. bisco
    51,837
    anyone know what mass tax credit will be?
    Prius Maximus likes this.
  2. Trollbait
    12,501
    Among friends, I think we can say the US, Canada, and South Korea test cycles are the same. Differences likely come down to rounding after converting units. There might be differences in the rules around the test cycles. The new EPA ones for 2016 were reported here. Have they been adopted by Canada and S. Korea? It was a few years after the US that Canada adopted the 5 cycles.
    The highlights of Japan's JC08; Duration: 1204 s, Total distance: 8.171 km, Average speed: 24.4 km/h (34.8 km/h excluding idle), Maximum speed: 81.6 km/h, and Load ratio: 29.7%.
    Emission Test Cycles: Japanese JC08 Cycle
    Info for Europe's test cycles is here, Emission Test Cycles: ECE 15 + EUDC / NEDC.
    For completeness, the EPA test, Detailed Test Information
    Eligible Vehicles List | MOR-EV
    The Prime isn't on there yet. The Energis and Sonata PHEV are at $1500, which makes that the safe bet for the Prime.
  3. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
  4. Jan Treur
    Jan Treur Active Member
    240
    168
    Heiloo, Netherlands
  5. bisco
    51,837
    too bad, i was hoping prime would be $2,500., since pip is $1,500.
  6. Trollbait
    12,501
    The Volt was the only PHEV that high.
  7. bisco
    51,837
    and it's also unfortunate that they don't lay out the parameters, like the federal credit, instead of just listing current vehicles. what is it, top secret?
  8. Tideland Prius
    16,547
    Yes, Canada adopted the 5-cycle in 2014. The numbers are pretty much identical to the EPA's.
  9. Tideland Prius
    16,547
    The 15% increase in price in the Netherlands, btw, include a lot of kit, some of which aren't available on the regular Prius. It comes with HUD, TSS-P and Matrix LED headlights (this is Prime-specific. No, we will not get it in the US thanks to DOT's antiquated requirements).
    What's Matrix LED? See No.3 in this thread. Toyota calls it "LED Array"
    Future Toyota Integrated Safety Systems (2015 Edition) | PriusChat
  10. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Pijoto, Ashlem and Tideland Prius like this.
  11. DavidA
    2,344
    1,820
    Chicago western burbs
  12. inferno
    inferno Senior Member
    1,072
    405
  13. Tideland Prius
    16,547
    That probably means $29,990 :p.
    I will be very surprised if it's closer to $25,000 because you need a separation between the Prius and Prius Prime (not to mention, Toyota needs to make a profit!). $25,000 is probably after the tax credit. I'm still sticking to my estimate of around $30,000 (basically, no change from PiP) or at worse maybe $32,000. They'll have to price it carefully because of the Bolt's announcement of 238 miles AER and at most $37,500 MSRP (could be less... who knows, but even at $37,500, it'll be competitive with Prime after the fed tax credit)
    Mister MMT likes this.
  14. bisco
    51,837
    there is already a separation between prius and prius prime. prius has 5 seats and larger hatch area, prime should be cheaper.
  15. Tideland Prius
    16,547
    Sure, let's just ignore the giant battery under the cargo floor. :rolleyes:
  16. DavidA
    2,344
    1,820
    Sure and while we're at it we should... wait... What? The giant what?
    Tideland Prius likes this.
  17. bisco
    51,837
    i can ignore the one under the floor, it's the one above the floor that's impossible to ignore.
    and btw? that battery is only giant compared to pip.
    if prime starts at 35k? they'll be rusting in the dealership lots.
  18. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
  19. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Purely a WAG, but the Prius 3 and Prius 4 are $2,400 apart, and from reading the posts here it looks like we'll be getting a Prime 3, Prime 4 and Prime 4 Touring as well as from some Pre-Order example that included the 11" on the Prime 4. So the Prius Prime 4 will probably be around $32,500 or the same as the base PiP in 2012/2013.
    Unsupervised!
    #99 drash, Sep 18, 2016
  20. CaliforniaPrius
    313
    201
    Alameda, California
    $32K minus feds and CA tax credit makes a $26 price tag. Not bad. A 2017 basic Volt after tax credit cost about the same. Still a good bargain for prius buyers.
