Honda UK has dropped ALL hybrids from its range!
Discussion in 'Honda/Acura Hybrids and EVs' started by GrumpyCabbie, Aug 29, 2015.
  1. ZeroTX
    ZeroTX Junior Member
    64
    Houston, TEXAS
    Wait wait wait, back up the truck: are you telling me that the Gen 2 Volt is basically just a standard plug-in parallel hybrid and not a serial anymore?? That was the whole beauty of the idea, that the generator power source was irrelevant... could have been diesel, gasoline, fuel cell, anything... Hrmph.
  2. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Well, even in Gen 1, at the right RPMs, the engine would be clutched in.
    With a diesel, the rev range would be largely the same, so you'd still be able to use it, assuming the torque curve was friendly to it.
    With a fuel cell, you'd use a completely different design for the powertrain, and it would look like an EV powertrain, or the traction motor of a Gen 1 Volt.
    In any case, the Gen 2 Volt's transmission does have a one-way clutch so both motors can contribute to propelling the vehicle (just like the Prius Prime will), or with a depleted battery, it behaves more like a Prius in concept (although with more complex modes, and therefore more complex power flows). And, the engine lags what happens with the accelerator, to try to make it feel like it's a generator responding to depletion of the battery, more than an integral part of the propulsion system.
  3. Trollbait
    12,658
    With the rule changes, it should be easier for most cars to beat the window sticker MPG figures now.
  4. prius_noob
    prius_noob Member
    151
    56
    United Kingdom
    Is there really "national pride" ? Maybe I spend my time with people like me, who aren't so fussed about national pride.. At any rate, a lot of people buy manuals here, because well Europe and most of the world have always been concerned with fuel economy. Today ofc, automatics are better for that.
    That, and as most people learn in manuals, they think that automatics might be a bit hard to drive. Certainly when I first drove my Prius, I was quite shaky!
  5. HobbsNick
    HobbsNick Member
    107
    156
    Newcastle, U.K.
    Similar experience here, as you say most people learn to drive manuals. From my perspective there are several factors, first of all if you learn to drive and pass your test in an auto then your licence only allows you to drive an auto going forward. This means that most people learn to drive a manual so they can drive both.
    Auto's in the past have also carried a stigma, down to them being easier to pass your test in as well as the performance being worse. This side has started to change in recent years with the emergence of high performance sports cars and hybrids using autos.
    The final thing is the increase in cost, the difference in price for example in a manual to an auto ford mondeo is considerable. A basic mondeo costs £21,445 ($28,208)the cheapest auto version is £27,005 ($35,522) Admittedly the cheapest auto is a higher spec, but even the manual version of the same spec is quite a lot cheaper at £23,495 ($30,905). The price is the biggest negative for UK buyers and means that mainly only people that have to buy autos buy them.
    The Prius helps break this pattern of thinking as you can only get it as an auto and that this isn't the main driver for buying one.
    prius_noob likes this.
  6. prius_noob
    prius_noob Member
    151
    56
    United Kingdom
    Agreed, RE: driving both. I've told my sister to learn in an auto though, owing to her dyspraxia, seeing as though well every one will drive autos in the future
    I did however live with a Chinese girl, for a short while, and she drove auto because she couldn't learn to drive manual, though also she managed to damage her (brand new) VW Polo by reversing in to the driveway, but luckily for her, only her lights cracked. There was no damage to any thing else. We didn't intentionally park near her after that :D
    I guess it also depends on how you buy cars, what kinda life you've been brought up with etc.. I got a 2011 Skoda Fabia. Cost of £4.7K. That was in 2015, so..four years old. A typical middle class way of buying cars ie: buy cars when they're four years old, and sell at eight years old. I betrayed my Asian "relative poverty" upbringing :D
    Now, I got the(£3K) 2007 Prius. It sure as hell has done like 100K more miles :D but it is so much better than a hell of a lot of new cars today! Though you are correct, otherwise I guess. I mean it depends on your car buying behaviour. I quite like this new method of mine - buy cars at 10 years old instead and keep for 4 years
    My next car will likely be an auto too, only because my next car will be another hybrid. I actually prefer to drive manuals, but hey I quite like the Prius!
    #66 prius_noob, Aug 7, 2016
    HobbsNick likes this.
  7. Tideland Prius
    16,607
    In most places in North America, passing the test in either will grant you a licence to drive with either transmission. I guess they figured the chances of you driving a manual (if you did your test with an automatic) is pretty damn low. Also, you would more likely be a car enthusiast and therefore you would voluntarily do your test with a manual car anyway (mostly for pride).
    An automatic option here is fairly cheap. ~Cdn$1,000 or US$800 give or take. So the uptake in automatic is high since $1,000 isn't too much.. 4-6% of the MSRP on the non-luxury market.
    Cars here seem to hold their value better than in the UK. Every time Top Gear or Fifth Gear does a used car segment, I can't believe how affordable 3-year-old cars are.
    I've found 2 year old Yarises for nearly the same price as new! (only $1,000 off.... and at that time, the government had a eco-rebate which dropped the new Yaris price by $2,000... so a new Yaris was $1,000 cheaper than what was advertised for sale on a 2 year old!)
  8. HobbsNick
    HobbsNick Member
    107
    156
    Newcastle, U.K.
    A lot of people who buy new replace their cars either every 2 to 3 years, either because they've bought them on 2 or 3 year finance deals, also once a car hits 3 years old it has to be tested every year to pass road worthy tests. Both of these mean we have a lot of young cars in the second hand car market hence driving the price down.
    What I find interesting is that Canada sold 1.9m cars last year compared to 2.6m in the U.K. which has double the pop, seeing these figures I'd assume that depreciation would be similar. Mind I believe cars are cheaper there as well people keeping new cars for longer, so hence they don't depreciate so quickly.
  9. prius_noob
    prius_noob Member
    151
    56
    United Kingdom
    Ahhh I think it's the case in most of the world tbh. It might be a tad different in the commonwealth too. Actually I think it is a similar drop in value, in Pakistan (And therefore I assume, India too)
    That would also explain why lots of Americans buy cars brand new, because well your cars hold their value really well. Toyota/Honda hold their value well though
    I think there's a reason why the middle classes tend to buy cars that are 4-8 years old!
  10. Tideland Prius
    16,607
    Ahh there's the kicker. I think most cars are either tested annually (even when new) or they have an exemption until their 3rd year. It's not implemented nationwide so each province or state will have their own regulations on what they test. (Usually it's just emissions, not a comprehensive checkup. That only occurs if you're moving to a different province and registering a car there).
    Canadians tend to keep their cars for longer. Our 2005 was 11.5 years old when we traded it in (bought new). Our 2010 is 7 years old (Also bought new). To save on depreciation, you can look for 1-2 year old cars (usually someone who is on a work visa, leased a car and then had to return to their home country early). There is also a "takeover" lease option where you takeover someone's lease of a vehicle. Or you can buy CPO (Certified Pre-Owned). That is when a vehicle is taken to a dealer of its own manufacture and it's given a comprehensive inspection. These are cars that are less than 5 years old and have less than 100,000km. CPO cars sell for a bit more than an identical car sold elsewhere since the dealer performed the inspection and certifies it to be in excellent condition. I think there's also a 1 year warranty on it but it might differ from manufacturer to manufacturer.
    Also, some places a family will have more than 2 vehicles so even though we have 1/2 the population, each person would "own" more than 1 vehicle due to households owning multiple vehicles. (e.g. 1 SUV, 1 minivan and 1 truck for work).
    I'm in the commonwealth (Canada). :D
    Yeah we buy 1/10th the number of cars (model to model) that Americans do. Toyota Canada sold in all of Canada less than half of what Toyota Motor Sales USA sells in just Camrys alone.
    Canada: ~37,000 Camrys
    USA: >400,000 Camrys
    TCI 2015: ~187,000 Toyota and Scion vehicles
  11. prius_noob
    prius_noob Member
    151
    56
    United Kingdom
    I assume then your cars depreciate like our cars in the UK depreciate? Cars in Europe depreciate very slowly too
    Though our fuel is really quite pricey! Though our version of the DMV (DVLA) is far better than what Americans have
  12. Tideland Prius
    16,607
    Not really. Toyotas and Hondas are pricey if you buy second hand from a dealer. Even privately, they mark it up (because of the higher price at the dealer)
  13. prius_noob
    prius_noob Member
    151
    56
    United Kingdom
    Fair enough. I figured that as this was the case in the UK and Pakistan, I thought it applied to the commonwealth in general!
  14. Tideland Prius
    16,607
    We're the weird cousin in the commonwealth lol. I think we're the only commonwealth country that isn't RHD!
  15. prius_noob
    prius_noob Member
    151
    56
    United Kingdom
    Nah you're like the good child, that turned a lot more liberal than their parents, but you have some weird kinks. The USA is like the bad child that went astray and now has too much power :D
    Seriously, I see Canada as UK #2, but better.
  16. Tideland Prius
    16,607
