Front License plate
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Taxi/Limo, Aug 8, 2016.
  1. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    Hi All
    I need to put a front license plate on my prius.
    I notice there are a couple little indents on my front bumper but no holes . Do I need to drill holes or something else here to mount a plate ??
    Thanks
    Nexus 6 ?
  2. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
    Mine came with the bumper drilled for license plate. Im guessing you have to drill yours to mount license plate
  3. orenji
    orenji Senior Member
    5,886
    3,487
    You will need the front plate holder as well, to mount the front plate to.
  4. huxington
    huxington New Member
    Los Angeles
    Please don't drill into your bumper! Purchase a plate relocation kit from ebay or amazon.
  5. Taxi/Limo
    524
    107
    I have never heard of a relocation kit
    Nexus 6 ?
  6. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    ...or just use some self-tapping screws. The bumper is only plastic, after all...
  7. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,458
    92
    Starbrand and sfv41901 like this.
  8. Mendel Leisk
    40,467
    There's a standard bracket available from Toyota, the dealership will have it for sure. Looks like this:
  9. huxington
    Los Angeles
    Brah, no.
    orenji and Dylan Doxey like this.
  10. Taxi/Limo
    524
    107
    I probably get one of those relocation kits
    Nexus 6 ?
    Dylan Doxey, huxington and orenji like this.
  11. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    Our state (Virginia) requires front licence plates. Somewhere on Priuschat I saw a different way to mount the OEM licence plate holder... instead of hooking the license plate mount's bottom grab brackets to the top of the grill opening slats, it looks a lot better to hook these grab brackets to the very bottom of the grill opening slats. This moves the licence plate from mostly above the grill to a mostly "within the grill" alignment, and IMHO looks much much better.ofncourse, the top screw holes must move down as well.
  12. Mendel Leisk
    40,467
    Check regs, for how low it can be. You might be ok. It would be a bit of grill block?
  13. DadofHedgehog
    681
    282
    northern Virginia
    I Winter-block my grille every year and it hasn't been a problem as the licence plate holder sits in front of the grille other than the two hook-tab arms.
    In the Summer, it's the top two grille openingsthat are key for cooling / ventilating the inverter radiator as well as the top of the normal radiator (heat rises etc).
  14. Starbrand
    Starbrand Senior Member
    493
    1,502
    Westmont, IL
  15. Taxi/Limo
    524
    107
    I checked with an ebay seller and he tells me most plate relocation kits do requre drilling so I have two questions
    1 Are there any plate relocation kits for the 2010 Prius that do not require drilling into the bumper?
    2 Which tow point license plate mounting kits will work with the prius?
    Dylan Doxey likes this.
  16. Taxi/Limo
    524
    107
    The tow hook plate holders I have seen that work with the Prius are around 40 dollars Are there any going for around 20?
    Nexus 6 ?
