  1. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    I thought about it, but in the end decided against for a few reasons:
    1) I would have had to find the proper connector to fit the Chrysler plug and then wire it into the turn signal or stock side marker wiring.
    2) The locating pins and bulb tube sit at an angle on the reflector, so drilling the bumper cover for them would have been a hassle.
    3) Trimming everything off (for a flat backside) and affixing the reflector to the outside of the bumper cover with no modification means it's completely reversible if I want to change the look someday.
  2. Lit Lit
    Lit Lit Active Member
    104
    340
    Northern California
    Have you or anyone else had any issues concerning to wifi? I kept getting this message.
    iPhone ?
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    No but sometimes I get an authentication error......again only sometimes
    iPhone ?
    Lit Lit likes this.
  4. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Same here. If I want to use wifi I have to resync. I think because to save data plan. Not a big deal. I don't use google maps or waze that much. More important to sync with Bluetooth. By the way you probably want to purchase a longer MIC cable
  5. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
  6. apt5020
    881
    1,294
    Prius City, CA
  7. BigBear2010
    BigBear2010 Member
    156
    65
    dont blow up the fuse :p
  8. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    Today is crunch time before tomorrow's show. Once I drop my co-worker off, I'm heading to Rodney's @HAWAIIANBUILT to pick up & install my JDM rear headrest Clazzio covers. Came right on time!
    Then I gotta wash car, reinstall front lip, get JAF emblem on new grill, fix e-brake cover, install invertor cover, trim some trunk floor a bit, try to get Remin pieces on. Roll in at 7am tomorrow.
  9. sd1810
    sd1810 Active Member
    105
    361
    Socal
    2015 Prius Plug-in
    Don't rush it brotha. We want your prius crispy, so fresh and clean. Represent!
    saulbassfan and Dylan Doxey like this.
  10. TopRamen
    TopRamen Senior Member
    307
    578
    Fremont, Ca.
    image.jpeg Haven't done anything to my Pri in awhile but someone did me in today. Just driving out of the parking lot of my work than "BAM!" lady backed into me. Well that sucks, Pri is no longer a virgin.
  11. MPGRaja
    MPGRaja Senior Member
    469
    1,679
    Corona
    Just drove back from Las Vegas to LA Hypemiling all the way. Hit 100MPH couple times:D. Round trip cost me only $30 and drove a little over 630 miles. Now it's time to give her a well deserved bath :love:. image.jpeg image.jpeg
    akh1685, Tracksyde, sfv41901 and 12 others like this.
  12. alisonc
    alisonc New Member
    Southeastern Michigan
    I had the wheels i bought yesterday mounted and TPMS swapped over -- 17s from a Scion tC. There's definitely an MPG hit, but i can feel that the handling is tighter and they look pretty badass. I also put on a rainbow stripe sticker and got the positioning of it a whole hell of a lot straighter than I am.
    Tracksyde, Vman455, sfv41901 and 13 others like this.
  13. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    Looks badass. (y)
  14. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
    Insurance claim = coilovers or maybe airbags :)
    sfv41901, Starbrand and Xterra72 like this.
  15. StarCaller
    StarCaller Senior Member
    1,275
    726
    Cedar Crest, NM, USA
    get rid of the little sticker on the left & get a decent license plate frame to make it look nice & clean//
  16. InspectorGadget
    InspectorGadget Active Member
    216
    450
    Heber City, Utah
    Awesome in more ways than one.
    Accordlayingkit and StarCaller like this.
  17. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    Looks great! What year tC did those wheels come out of?
  18. MPGRaja
    469
    1,679
    Corona
    2005-2010 tc wheels are all the same, standard.
    alisonc and WolfpackBill like this.
  19. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    Did Inverter coolant drain and fill yesterday. Easy peasy.....
    As my 2010 III ages (almost 120,000 miles)....all fluids are on the list (next up is engine coolant and Trans fluid). Will probably replace hoses while cooling system is drained (Colorado climate is rough on anything rubber).
    Also plan on doing from sway bar links Maybe next spring.
    #12939 Jimi1976, Aug 21, 2016
    sfv41901, orenji and granTORRESmo like this.
  20. saulbassfan
    979
    3,108
    Southern California
    From yesterday's Nisei Showoff
