Why does Gen4 feel a TON faster then Gen3?
Discussion in 'Gen 4 Prius Main Forum' started by 4rpr15, Aug 15, 2016.
  1. Tideland Prius
    16,406
    @4rpr15
    More technical reason (and I think the main reason why the Gen 4 feels more sprightly)
    First Drive of the 2017 Toyota Prius Prime PHEV-22 | Page 2 | CleanMPG
    Which @Jeff N summarises from a PriusChat thread (it's all a big circle... or network)
    ETP and 4rpr15 like this.
  2. Mendel Leisk
    40,245
    That's a bit troubling. Same here, in greater Vancouver: our nearby dealership at least appears to have nada. Got a call from them recently, asking if I wanted to trade up. They didn't say for what though. I've seen ONE 2016 Prius on their lot, they seemed to just have it as a demo.
    ETP likes this.
  3. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    Use PWR mode! Same MPG, touchier pedal, better A/C, much more fun. I've had PWR mode since day 1.
    Dragon Rider and 4rpr15 like this.
  4. ETP
    2,802
    1,170
    Auburdale FL
  5. Prius Five Guy
    170
    Los Angeles
    2013 Prius Plug-in
    Because plastic is lighter than metal...? The new model seems to have a lot of chintzy plastic "stuff"
    ETP likes this.
  6. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    But so did all previous Prius generations. There has always been an overabundance of plastic finish inside the Prius cabin.
    ETP likes this.
  7. ETP
    2,802
    1,170
    Auburdale FL
    The car does feel lighter but not sure if it really is on paper.
    Part of the weight saving is a knife comes out and makes you two inches shorter.
  8. Kenny94945
    Kenny94945 Active Member
    833
    412
    Sausalito
    2016 Prius v wagon
    Gearing.
    ETP likes this.
  9. Lee Jay
    Lee Jay Senior Member
    5,850
    4,029
    Westminster, Colorado
    It's not faster. It's just a different pedal position to power curve. What used to be power mode in Gen 3 is now normal mode in Gen 4 and power mode in gen 4 is a more aggressive curve yet. So you get more power at the same pedal position but the same performance at the floor.
    This fools you into thinking the car is faster when it's not. If you get 1/2 power at half pedal position where you used to get 1/3 power at half pedal position, your brain extrapolates that ratio to the end stop when the reality is the end stops are the same.
    ETP likes this.
  10. axle2152
    axle2152 Active Member
    266
    210
    Atlanta, GA
    2018 Prius Prime
    Let's see. I came from a 2013 Prius C One to a 2015 Dodge Challenger R/T and now traded that in for a 2016 Prius Two. What I can say while it isn't a car with 375 HP it does feel find driving it on the highway, almost the same on regular driving and no it isn't by any means the same as the Challenger. I haven't really done many hard accelerations other than to pass a couple people, got the car on Saturday.
    ETP likes this.
  11. Dragon Rider
    Dragon Rider Active Member
    344
    212
    Miami
    They get to price them higher over there. I think.
    ETP likes this.
  12. Mendel Leisk
    40,245
    I sometimes get to drive our previous Civic Hybrid, and am always taken aback by the hair-trigger accelerator response. I'm sure the Prius has a slight acceleration advantage, but it's soo much more linear/controlled. I prefer the latter. The 2016 Prius likely has a slight acceleration advantage over 3rd gen, but yeah, the impressions are mostly throttle and gas pedal response tweaks.
    ETP and Dragon Rider like this.
  13. Dragon Rider
    344
    212
    Miami
    We are not getting the full power on power mode ? Could this mean the Prius has more to offer ?
    ETP likes this.
  14. Mendel Leisk
    40,245
    None of the modes prevent "full throttle"; they just vary the intermediate response.
    ETP and kithmo like this.
  15. hb1148
    hb1148 Junior Member
    46
    56
    Jacksonville, Florida
    The 0-60 specs are actually pretty anemic but I agree it feels faster than I had expected having read the reviews. And now after several weeks of ownership, I find I have no problem in the daily road race/commute and passing in traffic when I need to. It may not keep people from going wide open throttle to avoid being shamed by being behind a Prius, but it makes them burn a lot more gas in the process. LOL
    ETP likes this.
  16. axle2152
    266
    210
    Atlanta, GA
    2018 Prius Prime
    If I remember correctly the Prius C was something like 11.8 seconds and the 2016 Prius supposedly reaches 60 just under 10 seconds. Might be slow for some but if anyone remembers the 80's it was quite common to have cars do 0-60 in 12+ seconds and were referred as a sports car. The worst 0-60 I've seen was a Pontiac 1000, took 30 seconds.
    ETP likes this.
  17. hb1148
    46
    56
    Yeah the current Prius runs around 10 seconds to 60. That's not bad by historical standards, I'm just comparing it to today. My first car was a 1976 Mercury Bobcat (basically a Pinto) and according to the interwebs did 0-60 in about 12.1 seconds. Like I said though, the Prius doesn't *feel* slow.
    ETP likes this.
  18. axle2152
    266
    210
    Atlanta, GA
    2018 Prius Prime
    I will also agree, mind you last week I was driving a Challenger with 375 HP which was able to do 5.5 seconds 0-60. I mean going from that to the Prius one would think they wouldn't enjoy how it drove but for normal driving drives just fine and able to pass other cars with ease. I can tell a difference but I can pass within a reasonable amount of time. I wouldn't want to attempt passing up a steep grade, I've done it in the past...better have a full battery if you do otherwise you might not have enough time.
    ETP likes this.
  19. ETP
    2,802
    1,170
    Auburdale FL
    They have fixed the avatar function where it works most of the time on most PICs. Come on guys. Time for real avatars.
    Cartoon characters, animals, and pretty women are my favorites. Please no wanted posters. However, legs hanging out from under a car would be a class act.
  20. raspy
    raspy Senior Member
    438
    699
    London, UK
    How did Car & Driver manage to get a Prius Two Eco doing 0-60 in 9.4? Or I guess that's because it weighs less? Toyota Prius 0-60 Times - 0-60 Specs
    ETP likes this.
