Gen 3 AC vs Gen 2 AC - Gen 2 AC better
Discussion in 'Gen 3 Prius Main Forum' started by wirelessjava, Aug 21, 2016.
  1. wirelessjava
    wirelessjava Member
    104
    Union City, CA
    Hello PC
    I do not know if people have noticed that the Gen 2 AC ( 2005) is way colder than the Gen 3 AC (2015 ) . Has anyone experienced this ? I just want to confirm that it is not just me
    ---Wire
  2. Steves895
    Steves895 Member
    48
    68
    Concord, NC
    I have a 2015 Prius, AC doesn't feel anywhere near as cold as on my 2012 Nissan Altima or wife's 2013 Nissan Rogue. I was going to have it checked at next service. I bought the car used, so just figured it's the nature of the car.
  3. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    It seems in the gen4 you need to run in power mode, I just stared to, I was concerned about how bad the air conditioning was in Eco mode, my gen 3 (wife has it for summers) is the perfect vehicle to travel with a dog, leave it on and the dog is fine, the gen4 was becoming problematic, but with power mode, it now works, summers, traveling with a dog
    As far as the difference between gen2 and gen3 air conditioning, there is none, I'm assuming the op was forgetting about the first generation of prii.
  4. AzWxGuy
    AzWxGuy Weather Guy
    1,051
    536
    Tucson, AZ
    2021 Prius
    Does the '15 have the three mode buttons, EV, ECO, and PWR? If set to ECO the A/C will be slightly less aggressive in cooling the cabin. Probably already know that. Could be reduced airflow because of a filter that needs replacing. Could have a leak too. I think my 2008 A/C worked about the same as my 2011, which for here in AZ in the middle of summer is pretty darn good. My 2011 did have a compressor failure a year ago though. Out of warranty. Shucks.
  5. wirelessjava
    wirelessjava Member
    104
    Union City, CA
    Thanks for the advice..... I am usually on ECO mode most of the time. I will put on power mode and see if this makes a dramatic difference. That is good to know. Thanks everyone for your input. I do not think this relatively new car has a AC leak.
    ---Wire
  6. bisco
    51,844
    i run eco all the time, and feel the a/c has been as good or better than my '08, up to about 98 degrees on the highway, high humidity and full sun.
  7. ChapmanF
    18,076
    Gen 3 introduced an ejector-cycle evaporator design.
    -Chap
    Steves895 likes this.
  8. AzWxGuy
    AzWxGuy Weather Guy
    1,051
    536
    Tucson, AZ
    2021 Prius
    I believe PWR only affects the response curve of the accelerator pedal. You can try it out though. I usually leave the modes off, or NORMAL.
  9. bisco
    51,844
    there is some type of a/c suppression in eco mode.
  10. Mendel Leisk
    41,332
    Could just be your third gen's refrigerant is a little low.
