AC won't blow cold after disconnecting 12v battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JakeRidesAgain, Aug 23, 2016.
  1. JakeRidesAgain
    JakeRidesAgain New Member
    Dallas, TX
    Okay, I'm trying to post a reply but it isn't letting me...let me see if this works.
    EDIT: THERE WE GO
    That's where I'm running into a problem with my troubleshooting process. As-is, I can't tell if the AC is even being commanded right now. I'm not sure if the button itself is bad, the climate control panel, or if there's a switch/relay somewhere that isn't doing what it's supposed to do.
    I did do a search today to see what switches might be hooked into the AC system and found one. It plugs into the AC line itself, and has a number of wires going into the passenger compartment. I wasn't sure if this was some sort of switch that might be involved in turning the AC on and off (I don't see how) or maybe contained a failsafe of some kind that kept the AC off when it's damaged.
    There's also the question of that fuse in the inverter itself, as posted above...I have no idea whether I should check that, and if I need to replace it, how I'd even do it.
    Ugh. This is bumming me out, especially since all this stems from me trying to fix a snapped lug stud.
  2. Mendel Leisk
    40,472
    Just a little humour: I'm picturing Jake typing away, arms like Popeye, lol.
    One thing that really jumps out for me: that the light on the AC button is not turning on. Maybe figure out what's up with that?
  3. JakeRidesAgain
    Dallas, TX
    Exactly what I'm thinking. I'm tempted to replace the climate control panel just to see if there's something screwy in there, at least then I can rule it out. It's weird I'm not getting a light on the button OR an error code, but I don't know how reliable the climate error code system is.
  4. JC91006
    JC91006 Senior Member
    16,656
    8,504
    Or possibly you disconnected the compressor by accident when doing the wheel thing on the passenger side
  5. JakeRidesAgain
    Dallas, TX
    Whoops, should have mentioned that. Had the wheel off on the driver side, so I wasn't even over there. I was following the same line of logic until I tracked down the location of the compressor.
  6. JC91006
    16,656
    8,504
    Well all the electrical stuff and fuses are on the drivers side. But I can't see that as a problem
    #26 JC91006, Aug 25, 2016
  7. JakeRidesAgain
    Dallas, TX
    Yeah, me either. It's all protected by the mud guard that's up in there.
    Uploaded the wiring diagram for the AC system if anyone is interested in maybe taking a look and telling me where I might be skipping a step. At lunch, I'm going to go see if the compressor kicks on when I start the car, and then run it to the AutoZone down the street and have them run trouble codes. I'll update if anything comes of it.
    Question: Could this be a symptom of a bad AC pressure switch maybe? This website gave me that suggestion, but I wasn't sure if it was a valid route of investigation or not.
  8. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    These extra wires might go to temp sensors in the cabin. If a sensor is bad, maybe it is telling the AC controller that it is cool enough and to shut off the AC.
  9. JakeRidesAgain
    Dallas, TX
    SOLVED!
    Oh, man, is my face red.
    It was a freaking wire plug! The damn thing wasn't seated all the way in, and I'm assuming since I live around the worst speedbumps/roadhumps ever, it jiggled out.
    Plugged it in, started the car, and held down the AC button. It went cold INSTANTLY.
    THANK YOU GUYS FOR ALL YOUR HELP. I never would have figured this out without y'alls patience and input, this place was instrumental toward guiding me to the right place to look.
    StarCaller, Mendel Leisk and DonDNH like this.
  10. JC91006
    16,656
    8,504
    this is on the compressor?
  11. DonDNH
    1,711
    654
    Nashua, NH
    Four Touring
    That's really good news. Stay cool!
  12. JakeRidesAgain
    Dallas, TX
    Under the passenger side dash, where the blower is. It's stashed far to the passenger side, way up underneath the glove box. There's three plugs up there, a wide one and two shorter ones. The top shorter plug had pulled out at some point, I'm assuming it wasn't seated correctly during service, and I guess it had just enough of a connection that everything was hunky dory until I drove it around for a few miles.
    JC91006 likes this.
  13. JC91006
    16,656
    8,504
    I'm glad you figured this out, maybe someone changed the AC cabin filter and somehow got that plug loose
  14. robertwa
    robertwa Junior Member
    Celebration, FL
    I'm having all of the same symptoms that JakeRidesAgain had. A/C worked perfectly before I changed the 12V battery. Now, the A/C light won't come on when the button is pressed.
    I took it to the dealership, and they said that the A/C system needed to be "reinitialized" and that I was low on Freon. They charged me $400 and the A/C was working when I left the lot. The A/C light stayed on and it blew cold. I went to work and parked for about 2 hours, and now the A/C light won't come back on at all and it blows hot.
    I checked the plugs that Jake described and they all seem fine. I really don't want to go back to the dealer because they tried to sell me $600 worth of extra stuff I didn't need and took twice as long to fix it as quoted. I was able to get a refund out of them, so that feels a little better. :)
    Does anyone know what the dealer did to "reinitialize" the A/C? Is that something I can do myself? Any other possible causes?
  15. Mendel Leisk
    40,472
    That's the smoking gun, right?
  16. Rebound
    Rebound Senior Member
    3,972
    2,626
    Portland, OR
    Dealers are supposed to warranty their repairs. You paid them $400 to fix your AC. They did not fix it.
  17. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    bring it back /
  18. robertwa
    Celebration, FL
    Yes, when it worked, the a/c light came on. Now, nothing happens when you push the A/C button.
  19. robertwa
    Celebration, FL
    I got a refund from them already. I'm just wondering if anyone else knows what the did to reinitialize the a/c.
    I reread my invoice and it says "Reinitialized a/c system using Toyota scan tools." Are there any non-dealer shops that have the Toyota scan tools? I feel like all of my local dealers are just trying to rip me off.
  20. Rebound
    3,972
    2,626
    Portland, OR
    The scan tool is called TechStream. You can buy one from Toyota for a few thousand dollars, or you can buy the cable and software from guys on eBay for about $20, and use your own Windows laptop.
    I bought a beat up $100 laptop with 32-bit Windows 7, which made things easy. I think the 64-bit TechStream hacked version is available now as well.
    I never used TechStream for AC, but that's where you start.
    Raytheeagle likes this.
