It's not the wheel bearing, so what's that noise??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Doug_M, Aug 25, 2016.
  1. Doug_M
    Doug_M Junior Member
    Boulder Co
    I have a whining/moaning noise from the front (left I believe) of my '09 Prius. I know it's not the wheel bearing because I changed that and it made no difference (duh..).
    The noise doesn't change with the gas pedal but is dependent on road speed. I hear it most obviously on smooth road surfaces, but that's probably just because there's less other noise to drown it out.
    It's not really really loud, but I want to fix it for safety/reliability reasons.
    Any ideas?
    Doug
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    954
    533
    Cow-lee-fornia
    2023 Prius
    I've heard that it could be the CV joints too if the boot ripped and there's no grease in the boot now.
  3. Doug_M
    Boulder Co
    The CV joint boot seems fine, and I didn't feel any play when I tried shaking the shaft around. Are there any other ways to test the CV joint? (replacing it, I suppose!).
    Doug
  4. bisco
    51,838
    cv joint noise changes when turning.
    how old are the tyres?
  5. JC91006
    JC91006 Senior Member
    16,761
    8,562
    Have you checked your tires?
  6. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Cooling pump turn on after car turn off to save the hot water
  7. Doug_M
    Boulder Co
    I don't think it's the CV joint. There isn't any weird noise when turning, and I can't detect any difference in the sound that is dependent on the load on the drive train.
    The tires are an interesting thought. They're at least 3 years old (when I got the car) and have at least 30k miles on them. They still have some tread life in them, and there's no sign of visible damage or uneven wear.
    Is there anything that might be a visible sign of a "noisy" tire? I can rotate them to different locations on the car, and see if that has an effect. They're not at the point where I want
  8. Doug_M
    Boulder Co
    It's not the pump. I'm familiar with that sound, and this sound happens when the car is moving.
    doug
  9. bisco
    51,838
    i have a noisy tyre with no visible signs, i can tell which wheel it's on. at 43k, i'm going to replace all of them, even though the tread is still fine.
    in the past, i had noisy tures, with visible cup marks in the outer tread. you can google 'tyre cupping'.
  10. valde3
    valde3 Senior Member
    2,002
    749
    Finland
    Rear wheel bearing? Jack up the back wheels and spin them to feel/hear if bearing is bad.
  11. Just_a_man
    Just_a_man Junior Member
    Edmonton, Canada
    I am aware that this is an old post... Just wondering if Doug_M had resolved the noise issue. It seems to be the same problem with my Prius 09.
