Question about energy arrows...
Discussion in 'Gen 2 Prius Technical Discussion' started by burritos, Jun 1, 2006.
  1. burritos
    burritos Senior Member
    4,946
    253
    The other day while sitting at a stoplight, I saw that the energy was flowing from the batter to the wheels. I turned off the light and the energy stopped flowing. Then I turned them back on and the energy still no longer flowed. Can you get a energy from the battery to the wheels to flow even when you aren't moving?
  2. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    <div class='quotetop'>QUOTE(burritos @ Jun 1 2006, 06:49 PM) [snapback]264329[/snapback]</div>
    I had that happen once where my foot was firmly on the brake and the screen started showing flow to the wheels. I think it was just a glitch in the matrix, it hasn't happend since.
  3. Tideland Prius
    16,551
    yeah.. if you're not pressing the brake hard enough at a light. Try it next time. Fully depress the brake pedal, then slowly lift until you see the arrows. The car still isn't moving since the battery power isn't enough to overcome the brakes.
  4. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    There's a little electrical energy being expended to provide the "creep" when you release the brakes. If you hold the brake a bit harder, the creep will stop and not draw power.
  5. keydiver
    keydiver New Member
    509
    Hobe Sound, Florida
    I've also noticed that it tends to do it a lot easier when I'm on a hill. I have to REALLY press on the brake to get the arrows off, so I *assume* it must be part of the Prius' "Hill-holding" feature.
