Leaving a cooler of ice in the Prius for hot weather.
Discussion in 'Gen 3 Prius Main Forum' started by Pijoto, Aug 30, 2016.
  1. Pijoto
    Pijoto Active Member
    200
    153
    Dallas, TX
    Just curious about this, does anyone leave a cooler of ice in their Prius while parked in hot weather? I live in Texas, and have been paranoid about my batteries longevity, so I've started leaving a cooler of ice bottles open in my car while parked at work. Would all that moisture in the car somehow hurt the electronics and batteries, anyway?
  2. matt b.
    matt b. Member
    251
    60
    L.A.
    I would say that it's unnecessary because there is a battery cooling fan right beside the right rear door so if the battery ever starts to get hot the fan will cool it down
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I do not, but MS suffers more for High humidity than truly hot weather. It was 96 yesterday with a max of 91% humidity and an average of 78%
    I am not not as concerned for the battery at rest as when it is generating internal heat charging and discharging.
  4. Mendel Leisk
    41,564
    @matt b. The fan does not work when the car is off. It'd actually be a good idea, if it could run a minute or two after shutdown, in hot conditions.
    @Pijoto I doubt very much a freezer pack sitting in the car will lower the battery's temp at all.
    N.J.PRIUS likes this.
  5. Pijoto
    200
    153
    Dallas, TX
    What's "MS"?
    He probably has a Solar Roof...though I once had my battery drop from 6 bars to 2 just for sitting a couple hours in the Sun once and wondered how that happened...I immediately bought a Sun windowshield cover after that :eek: I'll have to run some experiments to see how much cooler it keeps the car, but it does seem a bit nicer getting in my car after work with the ice cooler in there.
    #5 Pijoto, Aug 30, 2016
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Liability lawyers would have a field day if the fan could run when the car was off. The interlock to prevent the fan running when there were rear seat passengers or the case was open would be devilish. Owners with weak 12 batteries would be upset that the car did not start.
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    A state near TX also on the Gulf of Mexico.
    Perhaps the most Southern state, sadly not in a good way.
  8. Pijoto
    200
    153
    Dallas, TX
    Oh, haha...thought you meant an engine part :p It can get pretty humid in Dallas as well...
  9. bisco
    52,032
    would you mind doing a test for us? i'm thinking a thermometer in the car with and without the ice, parked in the same place, on days of similar temperature. would be interesting to know the measurements every hour or two.
  10. Pijoto
    200
    153
    Dallas, TX
    I'll have to test it over the weekend to do hourly comparisons, curious myself... I also place my cooler in the passenger seat (easier to grab my lunch I keep in there as well during my commute), so wondering if seat placement affects it.
  11. bisco
    52,032
    i would think the closer to the battery, the better, but not sure. if you can reduce the entire cabin temp, that would be great.
    Pijoto likes this.
  12. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
    Yeah.... water+batteries=what could go wrong? :D
    I'd strongly suggest you look into premium solar window tint; the kind that includes windshield applications.
  13. Pijoto
    200
    153
    Dallas, TX
    I freeze water bottles to keep in the car, so water isn't being evaporated into the cabin...but there's still condensation to consider, hopefully it won't be bad in the long run :unsure: Would be hesitant to go apply new window tint, when I'm pretty sure I got ripped off paying for the dealer window tint already....
  14. Mendel Leisk
    41,564
    It's not unusual for fans to run a minute or two after shutdown. One of our previous cars ran the AC and radiator fans thus, in hot weather, to avoid hot-soak I guess. If only for one or two minutes, not a lot of load, similar to headlights in auto setting.
  15. fotomoto
    5,638
    3,814
    So. Texas
    Yeah that's the usual dark tint that does more good for privacy and looks than for heat. The kick butt solar stuff is actually nearly clear and thus can be used on all windows including the windshield and reduces heat tremendously. It's not cheap but at least you would be benefiting from it too; not just the batt.
  16. Mendel Leisk
    41,564
    That's the impression I got from my "tinting days", that if anything it made things hotter, at least the aftermarket stuff we got. It was some sort of metallic reflective, I forget what exactly.
  17. StarCaller
    StarCaller Senior Member
    1,278
    730
    Cedar Crest, NM, USA
    overkill ////
  18. Pijoto
    200
    153
    Dallas, TX
    Ok, wow, just looked it up...that would be nice to have, especially on all the long distance trips I take. Never knew this existed, thanks for recommending it. One in Dallas has it, I'll have to check up on them before I make my next trip. - Solar Window Tint | UV Window Film | and Heat Blocking Films
    Most hybrid battery failures are in the hot weather regions and mountainous areas...and I live in Dallas :\ I want that battery to last well over 10 years...taking early precautions.
  19. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    I do worry about moisture/water in the car.
    The main thing we usually say is to use A/C to keep the batt cool.
    Interesting thought though. If you used those frozen-type packaged cooler inserts that would elim the moisture problem.
    Pijoto likes this.
  20. CR94
    CR94 Senior Member
    2,697
    1,174
    Northwestern S.C.
    A few gallons of plain cool water in the interior might absorb as much heat as the ice, with a better cost/benefit ratio. I considered doing that with a few plastic gallon milk bottles of water each morning, because I have to park my car in the S.C. sun nearly every day. Then I contemplated the risk of a bottle springing a leak above the battery ...
