How to disable Horn when locking/unlocking Car
Discussion in 'Gen 2 Prius Technical Discussion' started by CJ33, Mar 30, 2009.
  1. CJ33
    CJ33 New Member
    17
    Vallejo, CA
    I've just spend the past hour going throught threads on here and can't find a simple solution to this problem (if there even is one).
    I don't have the smart key fob. I just have the normal key fob for a 2006 Prius.
    When I turn the car off and lock the doors (either using the remote or using the door lock switch inside the door) the horn honks.
    The horn also honks when I unlock the car using the remote.
    How do you turn this off? It's annoying and my neighbors are complaining.
    I don't want it to honk at me anymore when I lock or unlock the doors.
  2. qbee42
    3,076
    I can't say with certainty, but I recall that you can't disable this "feature" on the base model.
    The SKS models have a very gentle beep when the doors lock. It is much nicer than a horn.
    WilDavis likes this.
  3. CJ33
    CJ33 New Member
    17
    Vallejo, CA
    Yeah, it seems no one can say with certainty... I don't have an SKS model, so the latter isn't an option for me.
  4. The Tramp
    The Tramp Italian Prius Expert
    369
    45
    Turin, Italy
    2020 Prius PHV
    That is curious: EU cars do nor beep nor horn when you open or close the car, SKS or not.
  5. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    I've got a 2004 'base' model, and it doesn't beep. When I picked it up, they asked, and I said 'no beep, please.' The dealer must be able to change the setting. Maybe there are instructions somewhere on John1701's site.
  6. CJ33
    CJ33 New Member
    17
    Vallejo, CA
    what is "John1701's site"?
  7. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    Check out www.john1701a.com. I haven't searched the site to find out if the answer to your horn question is there, but there's a wealth of useful information about the Prius.
  8. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Is this "remote" the same as the key fob? Is there a 3rd party or aftermarket alarm? My folks have a base 2006 and there is no horn.
  9. The Tramp
    369
    45
    Turin, Italy
    2020 Prius PHV
  10. CJ33
    CJ33 New Member
    17
    Vallejo, CA
    Yes, standard key fob.
    I bought the car used from a Honda Dealer who really didn't know much about Prius'.
    When I look under the driver's dash down by the pedals, there appears to be a kill switch over ride button hiding under the floormat. There's a blinking LED on it as well. It's not secured to anything, so it looks like there may have been an after market alarm installed at one point, but I don't have a remote for it.
    Would it be possible that is the cause of the horn to honk whenever I lock or unlock the doors using the factory key fob?
  11. qbee42
    3,076
    That sounds correct. I suspect an after market alarm. The more we talk about this, the more convinced I am that the base model does not beep when locking.
  12. CJ33
    CJ33 New Member
    17
    Vallejo, CA
    that's strange then.
    i've installed after market alarms in the past and generally the horn honk would be tied into the alarm itself.
    I can't find a head-end alarm unit anywhere in the car, so somehow they tied the actual wiring of the door locks into the horn because the car honks using not only the key fob, but also when in use the interior door locking button on the door itself.
    If I'm sitting in the car, turn the car off, open the door and then press the door lock button on the inside of the door they horn honks as well.
    So, if I make that assumption, does anyone know what wire would be tied into the horn to make this happen?
  13. darelldd
    6,057
    389
    Northern CA
    My first thought was aftermarket alarm. Somebody will have to confirm, but I don't think that the Prius ever used the horn as a lock alert.
  14. Bryan5
    Bryan5 New Member
    40
    MS
    Yeah I have a base 2008, and the horn doesn't go off when I lock/unlock the doors.
  15. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    Could there be an extra wire attached to the horn? But if you pull that, then the alarm won't sound at all, not just when you lock the car. Sounds like the 'beep' is in the aftermarket alarm unit - do you really need two alarm systems?
  16. RW5207
    RW5207 Junior Member
    32
    Dallas, TX
    2002 Prius
    I
    This sounds like someone added in a relay from the locking pulse going to the solenoid and connected it to the horn circuit for audible feedback, since it also occurs when manually locking the doors.
  17. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    My 2009 Gen II (touring) has SKS, and would never dream of honking at me!
  18. goodMXguy
    goodMXguy Junior Member
    44
    Philadelphia
    Not possible? Strange...
  19. bisco
    51,037
    anything is possible, but not everything is probable.
    Raytheeagle likes this.
