1. Manhal K Alrashdan
    Manhal K Alrashdan Junior Member
    81
    jordan
    Recently, when I ever press the brake while the head light or three AC is on, an error message appear for a few seconds :park malfunction. Any help is appreciated.
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    C2311 is an indicator of a low voltage issue. Have your auxiliary 12v battery checked.
  3. Mendel Leisk
    41,350
    Capture.JPG should read: Park function?
  4. M.Aqrbawi
    M.Aqrbawi Junior Member
    Jordan
    Bro let us know the solution if you have solved the problem, because i have the same problem.
    Thanks
  5. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Have you checked your 12v battery reading:)?
  6. M.Aqrbawi
    Jordan
    Yes i checked the 12V battery its okay, and i checked the P CON Main fuse it okay also, and checked the voltage while the car running its around 14V, and when the AC and Headlights ON it goes down to 13.4, but when pressing the brake pedal Voltage drops under 13 here the caution sign appears on the screen, and a code C2311 appears.
  7. BZzap!
    1,607
    878
    image.png Here is some information about this C2311 code. It seems that there may be a communication error in the hybrid transmission ECU. More diagnostics are probably in order. You should probably consult with a Toyota dealer in this case.
  8. M.Aqrbawi
    Jordan
    finally I found the solution, left front end ground connection (electrical connection to main body chassis) was loose, the connection was tightened and now every thing is okay.
