PSA: Change your 12 volt battery every 4 years
Discussion in 'Gen 3 Prius Main Forum' started by RaZa, Aug 24, 2016.
  1. Tbkilb01
    Tbkilb01 Active Member
    216
    187
    Louisiana
    Thank you for responses. Very GOOD STUFF! I think I might replace 12v battery being so old. I drive the prius daily allot. Also thinking of purchasing 2nd to offset wear/tear on single.
  2. Tbkilb01
    216
    187
    Louisiana
    These are upon initial READY today
  3. bisco
    51,045
    a second prius?
  4. Mendel Leisk
    40,506
    ALS likes this.
  5. CR94
    CR94 Senior Member
    2,662
    1,150
    Northwestern S.C.
    True, and even if those door lights are disconnected and all other interior lights are off, whenever any door (including hatch) is open there's still a sneaky drain roughly equal to a typical incandescent dome light. That alone will drain the battery in a couple of days.
  6. Tbkilb01
    216
    187
    Louisiana
    2009 141k touring edition one owner
    Maint records
  7. Tbkilb01
    216
    187
    Louisiana
    Well thats what Im wondering. She still works as designed, in all areas, just that HV BATTERY concern. I was wondeting about the reconditioning kit on PriusChat store...No biggy though, just wondering if I need to nip it in tbe BUD? I'll upload more after a drive.
    After short drive...
    #67 Tbkilb01, Sep 3, 2016
  8. eman08
    eman08 Active Member
    360
    192
    US
    I have 163k miles on my 09 still going strong with no signs of degradation yet as I can hold a Glide on electric for long stretches getting 60+ MPG. I live in the Midwest which is another factor for longevity compared to a very very hot regions.
    jdcollins5 likes this.
  9. Tbkilb01
    216
    187
    Louisiana
    Thanks for chiming in..,On level smooth roads I still glide and glides well I may add. Avg 50.04 after 5k city/hwy running with A/C and 65 MPH for 1.5 hrs, one way. .but the roads are hilly winding and windy.
    this particular drive was just a small stretch of expressway overpass while I was heading to the store to get oil for oil change. up and down overpasses for a bit, not really trying to glide just trying to get HV Battery to move charge up and down...Anybody have similar Elm data for comparison?
    #69 Tbkilb01, Sep 3, 2016
  10. eman08
    360
    192
    US
    Forgot to include my screen shots of my long coast and glides. I ecpect this HV battery pack to last me another 100k miles. I keep the HV battery cooling system and fan cleaned out often. Maintain, Maintain.. 1472954673543.jpg 1472954696399.jpg 1472954611612.jpg
  11. bisco
    51,045
    i hope you get it and more!(y)
  12. Tbkilb01
    216
    187
    Louisiana
  13. bisco
    51,045
    sorry, eman08's desire for another 100,000 miles in post #70.
    Tbkilb01 likes this.
  14. Tbkilb01
    216
    187
    Louisiana
    Most definitely!
  15. Tbkilb01
    216
    187
    Louisiana
    Yea this up and down hot humid cold and wet terrain isnt very nice to battery. I might just be over reaching and looking for premature fault after warning light popped up, right after cleaning the HV BATTERY cooling fan. I may just pull in to O'reilly Auto parts and pick out a new 12V and monitor for changes before ordering up a new HV BATTERY. Once I decide to get the 09,(fingers crossed) I'll have time to do some battery work on the '10.
  16. Tbkilb01
    216
    187
    Louisiana
    Today i read this for SOC
    Feeling better...still trying to figure out the ELM readings.
  17. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    The battery voltages do not look much different than mine. The system will trigger a DTC if the difference in voltage of adjacent modules is greater than 0.3V. Your largest difference that I see is 0.07V.
    From this reading I do not see a problem with your battery.
  18. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Did you go down a big incline today? The SOC Max at 93% is high. The system tries to limit SOC to 80%.
    It tries to keep SOC between 40 and 80%.
  19. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Haha. That is Engine Link being displayed on an iPhone, similar to Torque on Android. Trying to display 14 parameters on a phone display can cause overlap and crowding.
    I like to use my iPad with the larger screen when trying to display battery voltages, resistances, etc.
  20. xliderider
    xliderider Senior Member
    8,041
    3,213
    Honolulu, HI
    This thread is way off topic. It's supposed to be about the 12v auxiliary battery, not the traction battery and monitoring software and displays. SMH
    Raytheeagle and bisco like this.
