[Solved] Engine Coolant Temperature Sensor location?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Digestion_08, Sep 10, 2016.
  1. Digestion_08
    Digestion_08 New Member
    Orange, CA
    Hi all,
    Could someone help me locate the ECT sensor for a 2011 Prius so I can replace it ?
    Thank you.
  2. Mendel Leisk
    41,402
    I believe it's this:
    I've attached a Repair Manual excerpt on removal/install:
  3. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    19mm union nut wrench. I'm sure everyone's got one of those lying around...
    Raytheeagle likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    While everyone may not have one, a set of flare nut wrenches can be bought at harbor freight relatively cheaply ;). And it goes up to 22 mm so you're covered.
  5. Mendel Leisk
    41,402
    When I google "union nut wrench" I get all these hits for "flare nut wrench", which is essentially a box wrench with a smaller than open wrench opening, giving you two more corners, compared to an open ended wrench.
    Actually I don't see why a box wrench wouldn't work, you've removed the connected line first. Or a deep socket.
    I keep trying to justify getting one of these:
    I'm not sure, you might need to remove the wipers, their motors and the cowl (per @NutzAboutBolts video on spark plugs), but hopefully uneccessary.
    ThePrius11 likes this.
  6. Rebound
    3,996
    2,644
    Portland, OR
    Oh, snap! Another excuse to buy more tools!
    Digestion_08 and Raytheeagle like this.
  7. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    As if you needed an excuse to buy another tool:rolleyes:.
    I guess if @Mendel Leisk keeps supplying the repair manual, we'll find other tool needs:).
    I know my small garage is getting full, but always room for one more(y).
    Digestion_08 and Rebound like this.
  8. Rebound
    3,996
    2,644
    Portland, OR
    My rolling chest is taller than me, and it's packed! I never thought I'd fill it back when I bought it.
  9. Digestion_08
    Orange, CA
    Wow, thanks. You rock.
  10. Shahzad Nayyar
    Shahzad Nayyar Junior Member
    94
    25
    Pakistan
    Ok... reviving an old thread.... when u remove that ect sensor, does the coolant immediately come out? Is it kind of like, DIPPED in coolant. I removed my ECT but coolant did not come out. Rather it was after reving up for some 10 seconds that the coolant came out... Does that mean theres air in the system?
  11. Mendel Leisk
    41,402
    This is the component directly above the Exhaust Gas Recirc Cooler, sort of a T-connection with hoses leading in and out?
    In 2010~2011 model year, that component had a white cap you could unscrew for bleeding air. So I'd say yeah, that's the high point, and where air would likely connect. I would try to put it back together while coolant is flowing out.
  12. Shahzad Nayyar
    94
    25
    Pakistan
    Thanks for the prompt reply. I would do this tonight and get back to you. I was also thinking that initially the coolant came out but i put the sensor back once the coolant stopped coming out. What if the system had sucked in air
  13. Mendel Leisk
    41,402
    Not sure, but my hunch:
    The system is more likely to be pressurized than sucking, and that component is at the high point, so air collects there, as the coolant level rises (during refill). I think you've got rid of at least some of the air that was in there, improved things.
  14. Shahzad Nayyar
    94
    25
    Pakistan
    Ok one suggestion..... shud i fill the circuit from the area where the ect is removed from. U know, fill the circuit from the highest point
  15. AzusaPrius
    AzusaPrius Senior Member
    2,180
    920
    No leave that open and fill from the coolant tank until it comes out of the highest point.
  16. Mendel Leisk
    41,402
    I purposely drained some coolant when doing EGR cooler cleaning (to avoid spillage). My 2010 has the vent there, which I opened when pouring coolant back in at the reservoir, and as I did the pouring I could feel air rushing out at the vent.
  17. Shahzad Nayyar
    94
    25
    Pakistan
    With the car off or in READY?
  18. Mendel Leisk
    41,402
  19. AzusaPrius
    2,180
    920
    You want to turn the heater on all the way up full blast have the car running as you are filling it up, it would be best to put the car into maintenance mode.
  20. Shahzad Nayyar
    94
    25
    Pakistan
