Gen 4 HVAC usage and settings?
Discussion in 'Gen 4 Prius Technical Discussion' started by Blizzard_Persona, Aug 20, 2016.
  1. MichelleStone
    MichelleStone Senior Member
    549
    818
    Mariposa, CA
    Most of my driving is on long trips. Cooling the entire cabin is pretty important to me so I don't stick to the seats. While I don't have measured data, it seems like in the eco mode it takes a lot longer to cool the cabin. But it eventually gets there. Flipping on the normal AC gives me a power hit up front but evens out later on.
    kithmo, RCO and Blizzard_Persona like this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    Agreed. Also, I drive alone almost all the time, and I set it to driver priority mostly, but changing it to all outlets will give a boost. And we have only just got to Spring so far - was 27 C deg yesterday, so I needed to cool down quickly after working outside.
    RCO likes this.
  3. jdenenberg
    jdenenberg EE Professor
    3,919
    1,917
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I always turn off the ac compressor and turn up the fan speed a couple of minutes before reaching my destination. This drys off the evaporator coils and reduces the possibility of mold growth.
    JeffD
    RCO and HVAC like this.
  4. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    ctually
    Actually I set the eco on at the beginning of the summer and for enough cooling even on the 100 degree days. I thought that only turned off the passenger side vents. anyway my car was set at 65 and still is. I occasionally turn the air button off so it cools with outside air. It does little to the gas mileage. But then again Michelle I with you, I don't care what it does as long as I'm comfortable.
    RCO and alanclarkeau like this.
  5. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    I've been using the AC daily for 7 months. Tried both Normal mode & Eco mode. The output and coldness does seem to be somewhat reduced when the Eco button is turned on.
    But I haven't noticed any loss of MPG when I leave the AC set to "Normal." Nor have I noticed any gain in MPG when the AC is in Eco.
  6. Blizzard_Persona
    1,787
    946
    Pa.
    2023 Prius Prime
    XSE
    I have noticed that the car def cools better with it set to Normal and also NOT to driver only settings...
    I drive in ECO mode all the time so I have to remember to switch to Normal AC setting each time I turn on the car if I so choose since the car defaults to ECO due to the ECO drive mode. I have not been tracking the difference so who knows..
    The temperature has been steadily decreasing around these here parts so I will adjust as required..
    kithmo and Coast Cruiser like this.
  7. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    AC on full force: Yes, that's why I just use the manual mode. I can set my own fan speed.
    But when I did use Auto, every time I lowered the fan speed it would disconnect the Auto mode... So now I just use manual all the time.[/QUOTE]
    I believe when you select Auto for climate you are allowing the computer full authority to control the a/c. That means as soon as you change any of its idealised settings based on your original input it will relinquish all the control authority immediately. She's an all or nothing kinda control freak!
    alanclarkeau likes this.
  8. HVAC
    HVAC Member
    43
    44
    Seattle Area
    I believe when you select Auto for climate you are allowing the computer full authority to control the a/c. That means as soon as you change any of its idealised settings based on your original input it will relinquish all the control authority immediately. She's an all or nothing kinda control freak![/QUOTE]
  9. HVAC
    HVAC Member
    43
    44
    Seattle Area
    I find for us with efficiency in mind and control with out much effort then the following works well:
    Turn HVAC off before power off hybrid.
    When starting out, if we do not want the engine to start before 21 MPH or 2 bars on battery. We usually have 6 bars at start.
    After awhile if we do not want the windows down, turn HVAC AUTO on, Then AC off, in ECO. That is how we leave it unless we need the compressor for cooling. This actually makes me have more control without having to do anything further. I am a HVAC technician for what its worth. Lol
    #29 HVAC, Oct 3, 2016
    RCO likes this.
  10. Mendel Leisk
    40,484
    Yeah, was going to say: HVAC has GOT to know his HVAC. :)
    HVAC likes this.
  11. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    Something went wrong with my previous post. I was quoting Cost Cruiser with my comment below explaining what auto setting involves. Of course, far as hypermiling is concerned I bow to HVACs wisdom. :censored:
    HVAC likes this.
  12. HVAC
    HVAC Member
    43
    44
    Seattle Area
    Not all are as detail driven as you so I threw it out there...lol
    Very true, I have been doing it awhile and still find it worthwhile. I love how efficient the Prius is. Only using the power that is needed other than operator error. Lol
    What escapes a lot of people Is the setpoint, 73 for example is a heating and cooling setpoint. So if the car is below setpoint, then the engine is started to make warm water when there no other reason at the time... charging or propulsion.
    #32 HVAC, Oct 3, 2016
    RCO likes this.
  13. HVAC
    HVAC Member
    43
    44
    Seattle Area
    What is really strange for me is RCO's words above showed up as a post from me. Dangerous business,lol
    RCO likes this.
  14. HVAC
    HVAC Member
    43
    44
    Seattle Area
    For clarification you can be in Auto mode and have AC button off and everything will be Auto except the AC compressor will be disabled/off for cooling. The weather since owning the car, has not allowed me to determine if defrosting/ defogging in Auto, will let the compressor run with the AC button off.
    RCO likes this.
  15. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    I've actually had the heat on the last couple of mornings. Heater isn't that great.
  16. Blizzard_Persona
    1,787
    946
    Pa.
    2023 Prius Prime
    XSE
    Make sure the HVAC is on normal mode, and not eco possibly. It will probably heat up quicker.
    If your drive mode is set to ECO also, your HVAC will always default to Eco mode...
    RCO likes this.
  17. HVAC
    HVAC Member
    43
    44
    Seattle Area
    I see Boone is at 3300 elevation. Our Prius is garaged so we have not needed heat much yet. I am not sure if my heat is better than your generation car. I know it will warm up faster with exhaust gas reheat/recovery. My son has mountain bike raced in north inland NC at a college event.
  18. alanclarkeau
    7,045
    7,589
    We've just finished winter, and I don't generally like heaters in our MILD CLIMATE (or being particularly warm), but with my Mum in the car, she demands heat or puts on multi-layers of pullovers, cardigans etc then shivers to make me feel bad.
    I found the heater worked better with RECIRC, turn temp in AUTO to a high temp (think I wound it to 28C) turn off ECO and have it so it went to the back outlets as well, and to feet and face - that warmed the car up uncomfortably hot (for me) quite quickly.
    No, maybe the heater was as good as my VOLVOs and Euro FORDs - but they originate from much colder climes than ours.
    #38 alanclarkeau, Oct 3, 2016
    Rangerdavid and RCO like this.
  19. alanclarkeau
    7,045
    7,589
    Thanks, I'd worked out there was a SETPOINT, but was having trouble with working out what it was - that translates to 22.7C. I knew that if I had AUTO and 24 & A/C in the afternoon before, when I started up in the morning when it was a bit cooler - maybe 12 or 16, the ICE would start immediately and try to pump (unwelcome) heat into my nice cool cabin.
    RCO likes this.
  20. HVAC
    HVAC Member
    43
    44
    Seattle Area
    That is correct. If we need heat we wait until the engine starts for the other reasons about 3/4 mile from the house and then turn on the HVAC on auto with AC off. Have not had cold weather yet.
