Customized Body Electronics - can they be set without the hand-held tester?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Wiyosaya, Jun 5, 2006.
  1. Wiyosaya
    Wiyosaya Member
    298
    2024 Prius Prime
    XSE
    Well, I have searched for the answer to this question, and what I think that I have found is that you must have the hand-held tester to change any of the customized body electronics options that are found in this document. Is this correct, or has anyone been able to find a way to do this on without the tester? I picked up my '06 Seaside #5 last Friday, and I would like to have a couple of options changed. If it would save a trip to the dealer and possible charges, that would be wonderful. :D
    Thanks in advance!
    All the best,
    Matthew
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I know you can set the door locking options without the tester but I dont have the link to that. I know its here somewhere.
  3. Wiyosaya
    Wiyosaya Member
    298
    2024 Prius Prime
    XSE
    <div class='quotetop'>QUOTE(theforce @ Jun 5 2006, 12:18 PM) [snapback]265998[/snapback]</div>
    Thanks. I was able to figure that much out myself, and will "Read my Manual" :D tonight when I get home to figure out how to do this. However, there are other options that I'd like to do, too. Particularly the "Key in trunk" option (though I may not have a good reason to do this) and the passive mode option - although the tech at the dealer that I talked to said that they turn this on as part of their pre-delivery checklist.
    All the best,
    Matthew
  4. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    i don't think you can activate passive mode without the scantool. i don't recommend it actually... we had ours on passive for a week and changed it back. it was a serious pain. not so bad if you're the only one in the car at any given time... but otherwise, ick.
  5. Wiyosaya
    Wiyosaya Member
    298
    2024 Prius Prime
    XSE
    <div class='quotetop'>QUOTE(galaxee @ Jun 5 2006, 02:31 PM) [snapback]266091[/snapback]</div>
    Other than having the passenger door be openable when the FOB is outside the driver's door, I'm coming to realize that I will likely not have anything else changed as I gained a better understanding of one option and realized that it was how I would like it already, and the reason that I had for changing another option (being able to open the trunk latch if the FOB is left in the trunk) simply does not make sense. I gotta laugh at myself for thinking that it is possible for someone to get locked in the trunk of a Prius. DOH! :lol:
    And even having the passenger door open is something that must be done with the hand held tester on a 2006. After reviewing the manual tonight, I found that the manual specifically states that if you want this to happen, to contact your dealer. :( Must be that too many people found the option too hard to set in prior years and Toyota changed it for '06.
