Long life ok with Super long life antifreeze?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jensent, Oct 8, 2013.
  1. Jensent
    Jensent Junior Member
    25
    N Illinois
    Our GenIII needs to have the antifreeze topped off. I think it came from the factory with Super Long Life Antifreeze. I have some Long Life that we bought for our Tundra. (Mixed 50% with Distilled water) Will this be compatable with the SLL
    Thanks
  2. Mike500
    Mike500 Senior Member
    2,593
    767
    NO! Use only the antifreeze specified for the Prius.
    Topping off with water is better than introducing a non-compatible anti-freeze.
    I'd use nothing else.
  3. wjtracy
    wjtracy Senior Member
    11,367
    3,608
    Northern VA (NoVA)
    I agree with Mike think you need to stick 100% with the good stuff if at all possible.
  4. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    Prestone extended life antifreeze says it's compatible with all types of antifreeze. What does Toyota require?
    Galaxy Nexus ? 4
  5. mtbiker53
    mtbiker53 Junior Member
    87
    22
    cape cod
    If it's PINK,I'd use it..........
    steve
  6. Mike500
    2,593
    767
    Your car.......you are FREE to take the risk.
    The coolant runs through the inverter, has a specific PH and dielectric characteristics.\
    Weigh the savings, if any, against the cost of a new inverter.
    Also, if Toyota analyzes the antifreeze and finds foreign or non-conforming molecules in it, it might void any warranty claim, original or extended.
    Using it might not do anything. Do you feel lucky, today?
  7. genonervo
    genonervo Junior Member
    Boone, NC USA
    This coolant meets Toyota specs at walmart online; Valvoline Asian Vehicle Formula Antifreeze 871668 was $8.38 a few days ago now $11.97.
    I'm new...says I can't post links yet.
    • Silicate free, phosphate Hybrid Organic Acid Technology
    • Provides protection of 5 years or 150,000 miles
    • pre-mixed 50/50.
    • Color is pink
  8. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
  9. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    People,
    These alternate coolants are fine for Toyota non-hybrid cars. They are probably also fine for the Engine coolant loop in Toyota's Hybrid cars. They have not been tested or certified for use in the Inverter loop so use them at your own risk. I will stick to the Toyota SSL coolant in my 2016 Prius as I did in my 2004 Prius for 288k miles with no coolant related issues.
    JeffD
    dorunron likes this.
  10. StarCaller
    1,277
    729
    I was just helping out with the link/
    imho not worth to take a chance with non-toyota coolant//
    Raytheeagle likes this.
  11. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    You get what you pay for. I recommend the Toyota SLLC that is called for in the owners manual. To use any thing else is each individuals risk and choice.
    #11 dorunron, Oct 2, 2016
  12. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Toyota SLLC (00272-SLLC2), $15.16 at Camelback. 2007 Toyota Prius Parts - Camelback Toyota Parts - Genuine OEM Parts - Free Shipping
    You should be able to goto your local Toyota Parts department and ask them to match. Depending on the parts manager, he will come down from their full retail, arm & leg price, which is far greater than $20. The parts manager had no problem letting me have a gallon for $16.24 + tax. This wasn't as low as Camelbacks, but far cheaper than full retail price.
    Amazon has the Zerek Asian formulation for $14.06. Link
    So, are you that cheap not to go OEM fluid for an additional $2.18?
  13. Mendel Leisk
    41,401
    I just checked my bill, it was $19.14 Canadian. This was from a local dealership parts department, doesn't say anything about discounted.
    So not too bad, doesn't hurt to ask. This is something you get so infrequently too.
  14. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    According to one study, Toyota Prius is the least expensive car to maintain. It's the cheapest there is! So why cut a corner?
  15. Rebound
    3,996
    2,644
    Portland, OR
  16. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Oh, and the coolant for the engine DOES NOT "run through the inverter". That's a completely separate system. But I'd still use the correct Toyota specified stuff. A jug will last you a lifetime, unless you use it to change your own coolant.
  17. pvee
    pvee Junior Member
    2013 Prius v wagon
    That's what I was thinking. We had a hole in the inverter radiator. looked like about 1/4 inch. There was a dead bird laying down in there. I don't know if the bird actually did it.
  18. Mendel Leisk
    41,401
    As long as we're raising the dead, I can think of one good reason to use Long Life Coolant (versus Super Long Life Coolant), specifically when a water flush has been used due to contamination, stop-leak product or whatever. When there's residual, straight water in the system, you'll never got back to 50/50 mix, adding pre-mixed SLLC.
    (There's a link in my signature on this; on a phone turn it landscape to see signatures.)
  19. OptimusPriustus
    OptimusPriustus Active Member
    332
    141
    Finland
    With Gen3 Prius the most important question is why coolant level is down.
