Full thoughts on the new Prime (quick hits)
Discussion in 'Prime Main Forum (2017-2022)' started by inferno, Oct 4, 2016.
  1. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I should have said: hoping prices will be right.
    Right now we have only Netherlands prices which are promising.
    51,843
    thanks, me too! any announcement dates?
  3. Trollbait
    12,505
    Well, it is smaller than the traction pack, and it also has to sized to hold a buffer to run accessories while the car is in motion.
    But as I alluded too, this could have been a mistranlation error.
  4. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    To my understanding it is much smaller (in capacity) than the auxiliary battery.
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I'm a power electrical engineer, and I'm racking my brain trying to figure a reason to need a batter between the solar panel and the lithium battery.
    I've thought about boost converter isolation, static building up on the solar panel, faults causing shorts of the lithium pack, and so forth.
  6. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    It might have to do with variability of the voltage you'll get out of the Prime solar panel. From my count it looks like there will be 56 cells. If (warning big WAG assumption here) they are connected in series, then the voltage swings may go from 18V (nominal) to 33V (open circuit). So it kind of makes sense to go with a small battery that can handle wide voltage swings but not have to deal with constantly stepping up to the 208V of the traction battery which may also have to deal with constantly variable current as well.
    Unsupervised!
  7. Lee Jay
    5,850
    4,036
    A small NiMh battery can't handle voltage swings any more than a big Lithium battery can. Certainly not a factor of two. The varying cell voltage has to be turned into nearly-constant voltage charge current by a charge controller anyway.
  8. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Well from their own videos the ECU is the middle man for all of that anyways. Probably programmed for 3 paths: Solar to NiMH (wide voltage swings to small NiMH voltage), NiMH to Traction (small constant voltage to high voltage), and NiMH to 12V. Like I said a WAG.
    Unsupervised!
  9. inferno
    inferno Senior Member
    1,072
    405
    What's amazing about the Toyota hybrids especially the prius and probably the prime is the vast amount of mpg and efficiency possibility. Take my attachment for example. My ev for my pip almost matches the original prime estimate.
    Judging by that... If I drove the same way I could potentially get 45 miles ev in a prime. Close to the volt 2 at half the battery size! Also... Running on gas shouldn't make anyone feel bad at an average of 54 mpg which I'm sure more people would average around 60. That would be like a 30% improvement there.
    giora likes this.
  10. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    The trip you are showing was not on pure EV. Was it by gaming the sysrem collecting EV miles?
  11. inferno
    1,072
    405
    Pure EV is by definition correct?
    Yes, the entire trip was not an EV trip, it was hybrid + EV. I may have gamed the system, ie putting it in EV mode when the acceleration was low and/or costing and/or charging downhill. I believe this is like that "Auto" mode the Prime is going to have.
    The point is, I'm getting the high figures because of the EV miles counted. So if I drive the Prime the same way I should get higher. Yes though...it's not EV from start to finish.
  12. Trollbait
    12,505
    You might have done better in not trying to game it with EV mode use.
    Without a plug, all the energy used comes from gasoline. The battery captures some that would have been just thrown away, but the systems wants to keep a minimum charge in it for extended life. Use EV mode too much, which is easy with a small hybrid battery, and the car will end up burning gas wastefully to recharge the battery.
  13. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Better depends on what the driver wants to achieve.
    Sometimes, having more EV available is an advantage (and sometimes even a must) over best total efficiency of the system.
  14. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Knowing when to use limited EV is key... hence Prius plugless success.
    I have trips I routinely take where I'll be able to take advantage of Prime's charge-on-the-fly ability. The new mode will allow us to replenish EV on the highway for use later when keeping the engine off provides a greater return.
  15. Lee Jay
    5,850
    4,036
    I was sort of thinking the other way.
    When an ICE is running at very lower power, it's very inefficient. There are 35 zones on several of my routes that use less than 4kW to keep going. Using the ICE there is quite inefficient and I was thinking of using charge mode (if lacking Ev range, obviously) to make the ICE more efficient and then use the energy later.
    On the highway, the ICE is already efficient unless you're on a slight downslope.
    Thoughts?
  16. john1701a
    12,817
    5,303
    58
    I routinely take highway trips, some multi-day with no opportunity to plug in, then a bunch of short-distance driving. That makes charge-mode a no-brainer.
  17. Trollbait
    12,505
    Inferno can correct me if wrong, but I thought his Prius didn't have a plug.
    The gen4 non-PHEV will display EV miles traveled. To me, this just seems to be for ego stroking and boasting, while possibly encouraging inefficient driving.
  18. bisco
    51,843
    it's in his signature, that's what he was talking about. you don't get that display, or ev tracking in the gen 3.
    Trollbait likes this.
  19. Prius Maximus
    Prius Maximus Senior Member
    955
    810
    Northeastern IL
    Yeah, don't know why Gen 3 didn't have EV mile summary, I had it on my C. Not really useful for anything other than the occasional hey I've driven 4,800 miles without using a drop of gas... but it's nice to have.
  20. Trollbait
    12,505
    But those miles did use a drop, and more, of gas.
    Without a plug, the electricity in the battery came from:
    • Regenerative braking. This energy would have just been thrown away otherwise, but to get moving to begin with took gasoline at some point.
    • Directly charging it by the ICE, through MG1.
    Tracking these EV miles separately is misleading; giving the wrong impression on how the hybrid conserves fuel. You can put an ICE car in neutral and shut off the engine while coasting. Many cars actually turn off fuel delivery while coasting now. It took the engine to get it up to speed first though. So claiming those engine or fuel off miles as gas free would be dishonest, but that is what is going on by tracking a non-plug in hybrid's miles under EV operation is.
