Prime 0-60 :15 sec in EV mode
Discussion in 'Prime Main Forum (2017-2022)' started by fotomoto, Oct 3, 2016.
  1. fotomoto
    fotomoto Senior Member
    5,632
    3,809
    So. Texas
    Yeah those calculations are way, way off. Best to stick with real world results/feedback for now.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,034
    Westminster, Colorado
    Well, the 10.5 seconds to 60 in Hv mode is just about dead on, so I don't see why the other plot would be off by a factor of two, and with the wrong sign compared to the Hv mode plot. Plus, we have one guy saying its slower in Ev mode, one guy saying it's faster in Ev mode to 40 and one other guy saying it's really fast off the line in Ev mode.
  3. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    I guess we will have to wait for more tests .
    After all we have to keep in mind that probably no one has driven the real production model yet !
    The thing is,Toyota allways has promised more performance with each new Prius model,as they are doing with the Prime,but the truth is they don't differ very much in real life and 0-60 has been roughly the same since gen. 2 .
    It's not really important to me if it takes 10.5 or 11 seconds from 0-60,although I would find 15 sec. 0-60 in pure EV-Mode a bit disappointing ,what I am hoping for is better passing power .
    Not that I am disappointed with the passing power my gen. 3 gives me now,but if Toyota promises more performance for the Prime I would expect it in that category,especially because of dual electric motor support.
  4. Lee Jay
    5,850
    4,034
    2017 Toyota Prius Prime Plug-In Hybrid Drive – Review – Car and Driver
    "Faster to 40 mph Without the Four-Banger
    Toyota has teased us with a few more facts and numbers to bolster that impression: It says the Prime accelerates more quickly to 40 mph in its EV mode than it does in normal hybrid mode with the engine running. And it will accelerate to 60 mph, in either its EV or hybrid modes, in about the same time as the standard Prius—a claimed 10.6 seconds."
  5. fotomoto
    5,632
    3,809
    So. Texas
    Here's more to muddy things up. It's from the same source (Car and Driver) but from this weeks review not last July. (Bold mine)
    "Before, if you hit the gas pedal hard enough, the engine would be forced to pitch in as the single motor became overwhelmed. Now, with both motors pulling, the computer can leave the engine to remain as inert ballast at speeds up to 84 mph, at least until the battery depletes." 2017 Toyota Prius Prime First Drive – Review – Car and Driver
    Is it "can" or "will"? A subtle but big difference in EV operation.
  6. Lee Jay
    5,850
    4,034
    It's both. It will above a certain level of charge, and may not below that point depending on throttle position. At least, that's what I've read.
  7. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Maybe the can (bolding is yours) refers to EV Auto? who knows. They also say: "as the single motor became overwhelmed" (without the ICE) which is not true, the battery is the limiting component.
    As for me, if and when I slam the pedal due to emergency I want all the power the car can give, do not care if the ICE fires.
  8. fotomoto
    5,632
    3,809
    So. Texas
  9. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    "...Perhaps that's why the wind refuses to touch it. How else can you explain the Prius Prime's excellent 0.25 drag coefficient."
    Funny enough, someone explain this guy journalism and circus clown performance make ex-TopGear Clarkson unique?
    Ah, and he got fired.
    giora, bisco and Tideland Prius like this.
  10. Tideland Prius
    16,536
    So unless you're just hopping on/off the freeway (1-2 exits), it's best to use EV Auto or HV mode in extended highway driving (for passing power)
    telmo744 likes this.
  11. bwilson4web
    16,156
    • ~13 sec - Gen-1 Prius, ~120k miles
    • ~10 sec - Gen-3 Prius, ~73k miles
    Having owned both, they worked perfectly fine in traffic.
  12. Tideland Prius
    16,536
    I found my smart's 13.5 seconds a bit slow. The onramp close to my place when I owned the smart only allows me to hit 70km/h (44mph) before I run out of room on the onramp. Traffic is doing 110km/h-120km/h (68-75mph).
    I've used both automatic and manual mode. I find manual mode easier as I can downshift and rev up faster, as well as shift faster (As you may know, the 451 smart models have slow shifting transmissions).
  13. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    I totally agree with. The Prius has no problem keeping up with most 4cyl cars on the road. You just have to use 100% throttle. I find my Gen 3 not as slow as people assume it is.
    Montgomery likes this.
  14. Trollbait
    12,466
    But was it L.A. traffic?
    I have no complaints about the acceleration in the 2005 Prius, nor the HHR and Sonic that came after.
  15. fotomoto
    5,632
    3,809
    So. Texas
    The slow 0-60 EV times in my Energi are rarely an issue; however, I sometimes have to join a 75 mph rural interstate from a standing stop. There are no on ramps or side service roads so it's pedal-to-the-medal-full-speed-ahead-captain during peak traffic conditions. It's :08 sec HV mode is most welcomed and used then.
  16. civicdriver06
    797
    324
    Germany
    Can owners here confirm that ?
    12.2 sounds a bit slow .
  17. fotomoto
    5,632
    3,809
    So. Texas
  18. Lee Jay
    5,850
    4,034
  19. fotomoto
    5,632
    3,809
    So. Texas
    Yup. That was a much closer estimation to the real world data reported than your original guess based on Toyota's graph. (see below) When other corporations present information in such an ambiguous manner, it's referred to around here by some as "greenwashing". ;)
    My guess is there cannot be an "official" 0-60 EV time. Why? Because the system relies on many variables (temps, SOC, etc) in how much power it allows in EV mode. As they say, YMMV.
  20. Lee Jay
    5,850
    4,034
    If that graph had been correct, my analysis of it would have been correct. Since it had some units on it, it's really strange that it wasn't even close to correct.
