Prime midcycle improvements
Discussion in 'Prime Main Forum (2017-2022)' started by inferno, Oct 16, 2016.
  1. inferno
    inferno Senior Member
    1,072
    405
    • 5th seat probably coming...
    • Higher density batteries.
    • The prime has space for the charger in the back. If there was a creative way to place the charger perhaps the bed could be lower by 2 inches?
    • What if Toyota scaled back less battery but higher usable?
    • If prime had higher density batteries, higher usable, placed the cord somewhere else, less battery overall, couldn't the prime fit an optional spare with 3" bed
  2. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    How about making the 2 spots in back even more appealing by adding a heated-seat option and USB access?
    Seat cooling in front (like Lexus offers) would be really nice too.
    CHAdeMO for this market may be a draw as well.
    'LectroFuel likes this.
  3. wjtracy
    wjtracy Senior Member
    11,365
    3,608
    Northern VA (NoVA)
    Basically we in USA want more ft3 interior (111-ft3 is quite small) so that could mean ditching the solar charging option (which USA does not get anyways) and I think that frees up space. But seems like we need a slightly bigger frame and little higher roof in back. Basically we'd like what Prius hybrid was, smart design of exterior/interior to minimize battery impact on cargo space etc.
    Right now we are basically getting hybrid vehicles with plug-in option squeezed in.
    Personally they can make the battery 4-6 kWhr as for me. I like solar charging but I can put that equip in my garage, including the panel. In effect, CA demands min. 8 kWhr battery for ZEV credits, so we are stuck there.
    I view Toyota as going for what Japan needs which is highest possible MPG to reduce oil imports, and on-board solar charging, to reduce electric demand from power stations/grid. So a self-solar-charged Prime is actually incredible for that scenario. But it's not a USA scenario.
    #3 wjtracy, Oct 16, 2016
    Trollbait likes this.
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,034
    Westminster, Colorado
    My round-trip to work is 22.5 miles. My round trip to the flying field is 26.2 miles. My trip to my nearby family is 22.5 miles.
    This range is perfect for me.
    The biggest thing they did wrong with the whole G4 design in my opinion was the lack of interior storage options. That was one of the biggest selling points to me with my 2004. The Prime is actually better here than the regular G4 liftback.
    Yes, they should do a way better job packaging the batteries and put them under the rear seat where the G4 has them. They should fit.
    Along with that, they need to bring back the double glove box, put an organizer in the front bottom of the dash, fix the stupid placement of the gear shift, and put back the underfloor trays in the cargo area.
    Prius Maximus likes this.
  5. KrPtNk
    KrPtNk Active Member
    323
    283
    Pacific Northwest
    My two cents: I would love to have a converter that would make the car a backup generator. I have periodic power outages and I think I'm not alone here. It is offered in Japan, but the wattage is small when measured against American needs. I think we would need to have 2000 watts minimum.
    Jan Treur likes this.
  6. Lee Jay
    5,850
    4,034
    2000 Watt Continuous/4000 Watt Peak Power Inverter
    KrPtNk likes this.
  7. bisco
    51,741
    extend the body to match the extended rear end, and add another 3 or 4 cubic feet of space to the hatch.
  8. KrPtNk
    323
    283
    Pacific Northwest
    giora and bisco like this.
  9. Lee Jay
    5,850
    4,034
    With you there.
  10. bisco
    51,741
    wouldn't we all. and a built in block heater that runs off the evse, as someone suggested.
  11. Tideland Prius
    16,536
    The 4 seats is ok if they add more comfort like @john1701a suggested - A USB outlet in the back (the serious lack of charging options compared to the competition is odd). Heated rear seats would be nice too. (make it an option. No need to make it standard if Toyota wants to keep the starting MSRP low).
    I'm more concerned with the seats-up luggage space. On a road trip, I'd rather not have all my luggage visible by using the space above the tonneau cover for security reasons. If they can use the forecast higher density batteries to level/flatten the floor to the door sill, I'd be a happy camper.
    The contrast interior options (Moonstone) is nice but perhaps have the black areas covering the areas more likely to be worn (i.e. the seat bottom bolsters).
    Offer other interior trim options such as faux carbon fibre (like the MIRAI), piano black or satin silver or liquid grey (bright silver is overdone).
  12. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    All pre-production up to now !
    I remember that gen 3. didn't even have any USB outlet when launched,but no one had to wait for the refresh for it to be an option .
    What is more surprising to me that it has no vents in the back,yes there will be the usual ones under the seat,but it's not quite the same as the competitors offer .
    But as i said pre-production,so who knows?
    #12 civicdriver06, Oct 16, 2016
  13. Trollbait
    12,466
    The ability of the Prime to supply emergency power to a home requires the CHAdeMO plug and a special 'backwards' EVSE that is actually the out put invertor. Some of those should be available for the Mirai to power a home, and they are likely around $10k.
    KrPtNk likes this.
  14. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I was under the impression that the PiP2 in Japan will have an optional 100VAC 1.5kW outlet at the back which does not need "CHAdeMO plug and a special 'backwards' EVSE" and that is what @KrPtNk was looking for (but increased to at least 2kW).
    Can you elaborate on the 'backward' EVSE? Never heard of such.
  15. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    ^Could be this?
  16. Trollbait
    12,466
    There was some photos in one of the threads of an orange adapter that allowed plugging an appliance into the Prime's charge port. I don't think such would meet the needs for emergency home power. It was powering a tea kettle at a picnic in the photos.
    I called the other device a 'backwards' EVSE because it can charge the car, and also transfer electricity from the car to power the home. They available in Japan, and might be available in California for use with the Mirai.
    2016 Toyota Mirai Power-Out Jack Could Run Your Home In Emergencies
  17. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    In power outage, 1.5-2kW source is of help. Not to heat the home but at least some light, watching TV, chatting at PC and more.
    bisco and KrPtNk like this.
  18. Lee Jay
    5,850
    4,034
    The main thing I used my 2000W inverter for in a power outage is running my refrigerator and my freezer. I use my 300W one for the fan on my fireplace and miscellaneous things like charging phones, and powering things like LED lights.
    The average US home draws an average of 1000W (that's a 24 hour average). The large use for my inverter is starting up the compressor motors in those refrigeration devices. Running load is only about 150W.
    KrPtNk and Prius Maximus like this.
  19. Trollbait
    12,466
    The PiP had an option for providing emergency power in Japan. Many asked we it wasn't available outside of Japan. The answer is because it required CHAdeMO(which a comment by a Toyota rep says is true of the Prime) and power station, or Toyota doesn't see the need for providing a small inverter that meets other markets electric standards.
    Perhaps the small one will be available in the refresh, but I expect it to be like factory Nav; overpriced and not as flexible as aftermarket.
  20. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    I did not know this, can you provide a reference?
    CHAdeMO is, as far as I know, a fast DC charging type in which the charger is in the charging station and DC current is provided to the car bypassing its charger. Don't understand what this has to do with an AC outlet?
