New to owning a prius. Help!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jennifer O Elmont, Oct 20, 2016.
  1. Jennifer O Elmont
    Jennifer O Elmont New Member
    Utah
    I have owned a 2009 prius for a few months now. I need some advice please!
    1. What are the best tires for fuel economy, noise and pricing.
    2. One of my headlights shorts out a minute or two after turning them on. Is this fixable?
    3. I am noticing that the car is burning oil. Do I need to worry about that?
    4. What is the best oil to use?
    I don't know much about cars, and I don't have a lot of money...but I do LOVE my prius! Thanks in advance for your advice!
  2. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    If you have Costco membership, go there. Great value that is hard to beat, esp since the $70 off 4 tires promo seems to always run for Bridgestone or Michelin.
    Sounds like you have HID headlights? Might be the common ballast problem.
    Always check the oil level on a regular basis and fill to the top dimple mark.
    Use 5W-30, any major brand of your choice. You can switch to 10W-30, but it is a thicker oil, and you MPGs might suffer a bit, but oil consumption might be a little slower.
    Jennifer O Elmont likes this.
  3. Jennifer O Elmont
    Utah
    Than you so much! I will do it!
  4. orenji
    orenji Senior Member
    5,887
    3,488
    You live in Utah, and with the low temps you will have in the winter, you should use 0W-30 oil, not a 5W or 10W weight oil. Also, I suggest you change your oil every 5K miles.
  5. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    1. If you get lots of snow, you may consider Nokian WRG3 tires. If not I liked Michelin Energy Saver A/S tires.
    2. Unlike filament bulbs, HID bulbs "burn out" by blinking on and off then eventually staying off when warm. High-intensity discharge lamp - Wikipedia If so, replace the bulb. (Read up on replacing HID Bulbs, check youtube for videos)
    3&4. Check it weekly, use 5w30 conventional oil.
  6. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    I'm in California driven nearly 400,000 lots of bad tires Pirelli and Toyo cost me 3mpg until tread worn down to 1/8"
    Good Year integrity series are a soft tire that gets good regeneration when breaking and good gas mileage. But the best I've found is the Bridgestone Ecopia series
    iPhone ?
    orenji likes this.
  7. bisco
    51,495
    congrats and welcome! how do you measure how much oil it is burning?
  8. exstudent
    2,214
    905
    Torrance, CA
    OP has a Gen2.
    Gen2 (2004-2009) in US are specified for 5W-30 & 5K mile oil change intervals due to conventional oil.
    Yes, she could use 0W-30, but make life easier for her.
    Gen3 (2010-2015) & Gen1-Cs (2012-?) in US are specified for 0W-20 synthetic oil & 10K mile oil change intervals, due to the synthetic oil.
  9. orenji
    5,887
    3,488
    We all know the reason behind 10K mile oil changes and using 0W-20 weight oil. Well maybe we don't all know ;) Anyway this has been discussed before so if interested do a search. But basically its highly recommended that oil be changed at 5K miles, and 0W oil be used in harsh winter climates, as the oil will flow faster on cold starts.
  10. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    Jennifer I just wanted to give you a little more information about what I have found to be helpful. I use Amsoil Synthetic, and I stand by that for my Pruis and any other cars I've owned. I drive a lot of miles and Iive in Wisconsin, I just put on 4 Continental tires, from Discount Tire, they are 90,000 tread life warranty and low roll resitance, I've had them on 4,000 miles and they seem to be working quite well. They are Control Contact Tour AS, and those are only at Discount, if you don't have a Discount tire near you, they are the same as the Continental True Contact. You are in the right place Prius Chat is awesome
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,832
    Clearwater, Florida
    Goodyear integrity tires are the biggest price of crap tires ever made. God awful.
