Rear bumper fitment
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by PaulG4, Nov 2, 2016.
  1. PaulG4
    PaulG4 Junior Member
    UK
    Hi everybody,
    Unfortunately somebody drove into my car in a car park and dislodged the right-hand side of the rear bumper. This is a body-coloured part to the right of the black centre section.
    The dealer wants to charge me one hour's labour to take the bumper off and see if the part can be clipped back in again. I thought if there were any workshop diagrams out there I would give it a go myself.
    Has anybody seen any documentation about the rear bumper on the net?
    Thanks
    Paul.
  2. bigmichaelkim
    bigmichaelkim Member
    70
    US
    Hey Paul I am not an expert but I think posting pictures would help you in your quest. Good luck.
  3. Mendel Leisk
    41,163
    this'd be hit-and-run: file a claim on your insurance , get it done professionally?
  4. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    The Curt Hitch for the 2016 installation guide has some drawings and photos -- they might even have a video by now -- showing bumper removal that might be of some help.
    Edit: Here is a link
    Hitch Lookup for 2016 Toyota Prius
    #4 ATHiker, Nov 2, 2016
    RCO likes this.
  5. PaulG4
    UK
    Thanks for the advice, everybody. Yes it is a hit and run and would be covered but unfortunately there are complications.
    My Prius is parked in a numbered bay in a private car park, on the end of a row. My next door neighbour, who is not a great driver, crashed into it on her way out. Hasn't owned up, I'm afraid. Normally I would get the damage fixed straight away, especially as the rest of the car is still mint, but if she has crashed into it already after only a few months, I'm pretty sure she will do it again.
    So no plans to repair it properly for now. The towing hook instructions were good, ATHiker, all looks quite simple under there so I might have a pop at taking it apart. Usually though I find these things just pop straight back in if there's no breakage, and since it won't do that I guess a clip has broken.
    I've attached a picture of the damage anyway.
    Cheers
    Paul.
    grape808, RCO and Mendel Leisk like this.
  6. Mendel Leisk
    41,163
    Looks kinda cool as is, skull 'n cross bones. :)
    PaulG4 likes this.
  7. lohikaarme
    lohikaarme Active Member
    337
    337
    NY
    2023 Prius
    Limited AWD-e
    it is very easy to take off the bumper cover. It is something like 12 plastic push pins under the car, one little plastic push pin in each wheel well, and there are four screws when you lift the trunk hatch (two are black plastic screws you immediately see, and the other two are behind the black plastic panels that are against the tail lights which pry right off). After that, the side walls of the bumper cover pull straight out and the entire cover with lower parts of the tail lights come off.
    To prevent scratching you put masking tape along the seams of the cover
    The part you have taped on might be messed up a little. It plugs into the main bumper cover and then there are 2 plastic "wedge" clips that hold it on. Then there is also a screw that attaches is to the black plastic part of the bumper cover. If it is hanging like that, chances are there is something wrong with the "wedge" connectors.
    Nevertheless the scariest part of the whole procedure is pulling the side walls out- but the whole process takes less than 5 minutes if you know what you are doing.
    PaulG4 likes this.
  8. lohikaarme
    337
    337
    NY
    2023 Prius
    Limited AWD-e
    2016 Toyota Prius Manuals
    look at the TPA Rear pdf
    After everything is disconnected the parts circled in red are tabs that are sandwiched between two clips. you pull this straight out to disengage. The covers all come off the toyotas the same way- you could probably find youtube video of similar. Only other thing is there are two clips by the latch that hold the bumper cover against the back of the car. You just pull the cover straight back away from the car once the sides are disengaged to take it all off.
    #8 lohikaarme, Nov 7, 2016
    PaulG4 and grape808 like this.
  9. PaulG4
    UK
    Nice, thanks very much for that, lohikaarme!
    Paul.
