Cold weather mileage hit
Discussion in 'Gen 4 Prius Fuel Economy' started by ultravorx, Nov 8, 2016.
  1. ultravorx
    ultravorx Junior Member
    Pa
    Three Touring
    so I recently picked up a new Prius 3 touring and was getting great mileage. Averaging 56-58mpg hand calculated. This is with 80% highway at 65mph and 20% back roads around 40mph. Temps averaged 70f
    With the recent drop in temps around 35-50f I'm only averaging 46-48mpg hand calculated.
    It seems the lithium ion batteries may decrease performance a lot during the colder months.
    Now I did expect a drop but not 10mpg!!
    51,028
    might be gas formulation as well. what did your old prius do? i didn't notice a larger delta from my 2008 to pip.
  3. ultravorx
    Pa
    Three Touring
    My old Prius v only took a 2-3 mpg hit during the winter with same driving.
  4. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    Unlikely to be anything to do with the lithium-ion batteries.
    There are multiple things conspiring to increase fuel consumption at lower temperatures:
    Higher air density, reduced flexibility of tires, increased drag with wet roads, increased viscosity of oils, increased energy consumption of auxiliaries such as lights and heating. Increased engine run time due to engine running to provide heat. The list goes on...
    I used to have a gen2 Prius and even in California with mild winters it was very noticable. I did a couple of things to improve winter mileage. Blank off the radiator with pipe lagging (probably not necessary with gen 3 or 4). Created what is usually known as a "thermistor hack" to make the engine control believe the system wartms up quicker than it really did - that brought back the winter mileage to similar to summer.
    If you look back through old posts you should be able to find a number on the subject.
    kevin
    first_superior_prius, RCO and krmcg like this.
  5. bisco
    51,028
    wow, that's a big difference. let's see what other ten 4 owners report. have you checked all the usual suspects?
  6. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    YOU CAN STILL BE THANKFUL. :)
    If I lived in Pennsylvania, and all that snow, and cold, and I was getting 48 MPG… I think I would be doing backflips with happiness! :D I've never gotten 48 MPG in ANY car, at any time.
    Please explain "Delta." The only delta I see, is taking off from the runway at the nearby airport.
    RCO and bisco like this.
  7. Mendel Leisk
    40,471
    4th gen Prius seems VERY willing to go electric, even at cold start up? This seems instrumental to the amazing mpg reports.
    Maybe that behaviour is (by design) backing off as ambient temps drop, getting you closer to 3'rd gen behaviour, and mpg?
    RCO and Coast Cruiser like this.
  8. krmcg
    2,592
    2,391
    Whittier, CA
    Delta mean "difference". The delta between 50 MPG and 46 MPG is 4 MPG.
    RCO, bisco and Coast Cruiser like this.
  9. raspy
    raspy Senior Member
    438
    699
    London, UK
    Yes, in the summer, it used to go straight into electric, even when switching on first thing in the morning., which I always found odd, as a 1st time Prius user. Now, in winter, I 'feel' the engine kicks in a lot, and since the engine sounds coarse (I come from a 3.2 V6), it loses part of it's charm. I am doing a drive at 6.30am tomorrow when it will be close to freezing, I should check on the dash how much of the commute it stays in EV.
    RCO likes this.
  10. Coast Cruiser
    2,267
    2,571
    My ICE immediately comes on in the morning when I turn the defroster on. Or the AC, (which comes on with the defroster). But that's fine with me, I like warming up the gas engine.
    I want all systems warmed up, oil circulating, and A-OK ready-to-go when I start out for the day. :)
    Heater going when it's cold, and AC blasting when it's 90!
    The mpg in my car has been so good, I could stomp the gas pedal to the floor every time I leave a stoplight and still get 62 mpg. :ROFLMAO: (Or maybe the mpg display is stuck?)
    RCO likes this.
  11. greenmonster01
    106
    79
    Southeastern MA
    I noticed a difference between morning commute and evening due to the temp difference, but since I only have 250 miles on my ECO, I'm not really worried about it. Need a bigger sample to really start to draw conclusions.
    It was in the 30's this morning (60 mpg) so I was using heat, and it's 60 degrees now, so I'd expect to hit closer to 70 mpg going home. My numbers are also complicated by the fact that home is 20 feet above sea level, while work is 250 feet above. So I'm going uphill on the way in, and downhill on the way home...
    I was up to 70 mpg lifetime total, but due to the weather, I've lost 2.5 mpg each of the last 2 days... I'm currently at 65.x now lifetime.
    As long as I match (or slightly beat) the EPA numbers, I'll be happy, but since we're going into colder weather now, I might have to wait till summer to get my numbers back up...
  12. bisco
    51,028
    i stole that from bob wilson.:oops:
    Coast Cruiser and RCO like this.
  13. Mendel Leisk
    40,471
    Delta Dawn, what's that flower you've got on...
    altdel, Coast Cruiser and bisco like this.
  14. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    Drove my first 60 miles from dealer's today. Temperature ~+10C or 50F some city driving and some highway between 20-75 mph. Rain, wipers on intermittent a/c on auto 20C. Too delighted with first drive to remember to look at mpg but last noticed around 63 mpg on twisting switchback roads. Went into the red zone more than I really wanted but in traffic and didn't want to cause holdup.
    Coast Cruiser, krmcg and bisco like this.
  15. bisco
    51,028
    congrats! didn't know you got yours.(y)
    RCO likes this.
  16. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    Yup. Picked up the car and keys midday yesterday,(Tuesday). :):):)
    bisco and Mendel Leisk like this.
  17. Coast Cruiser
    2,267
    2,571
    What model and color? Is this your first Prius?
    I see a thousand new Honda Civics in this area, and only 5 or 6 new Prius's. That Honda is a sharp looking car.
  18. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    You forgot me already! How could you? The next 5 burgers are on you! :ROFLMAO:
    Got a Hypersonic Red business edition, that's like your three non touring. It has 15" wheels with Toyo tyres, no sat nav or sun/moon roof. Driven 71.9 miles and averaging 63.4 mpg on the screen.
  19. Coast Cruiser
    2,267
    2,571
    Congratulations RCO. That red is a great color.
    RCO likes this.
  20. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    Does that mean the paleface approved of the redskin???? :oops::unsure:
    Hope are you liking your new president elect. We are with you no matter what comes next so buckle up. If it's like our Brexit you're in for a bumpy ride for a short while but it's gonna be fine.
