Axle Beam Sub Frame Rust!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by eman08, Nov 1, 2016.
Tags:
  1. eman08
    eman08 Active Member
    360
    192
    US
    About to make this my weekend project. What do you all think about this? Does the metal look cracked to you? Replace the whole thing or wire brush it down and spray some rubber coating?
    51,510
    wow! is that road salt? i think it's okay, brush and coat sounds good. haven't heard of any failures yet.
    eman08 likes this.
  3. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    515
    Outside Philly, PA
    What coating are you considering using?
    eman08 likes this.
  4. eman08
    360
    192
    US
    Yup. I live in Iowa which is the norm of road salt lot of snow up here. undecided for the coating though as there are so many of them out there. Used rustoleum products for quite some time.
  5. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    por15 seems to be mighty tough stuff.
  6. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    I wouldn't waste my time with it, that is MINOR for a "rust belt" car and as you confirmed, Iowa definitely qualifies!
    If you are gung-ho, wire brush, then a wipe-down with "glaze remover" would be highly effective prior to application of spray undercoating.
  7. valde3
    valde3 Senior Member
    2,002
    748
    Finland
    Looks pretty normal. I don’t see any cracks or anything other than surface rust (but it’s really impossible to tell from picture).
    If you decide to coat it with something eather sand blast it (probably not practical) or cavity wax type of thing that can be applied directly to rust (as wire brush does only remove lose rust) you can then use rubberized undercoating on top of that. Just putting on undercoating won’t really help.
    #7 valde3, Nov 2, 2016
  8. Mendel Leisk
    40,955
    Toyota suspensions, in particular the bolts, seem to display a dismaying amount of rust. Our slew of Hondas never exhibited this inexorable, wide-spread rust. Something to do with legislation reducing the ability to use the more effective rust preventing coatings/finishes? Due to toxicity?
  9. 05PreeUs
    1,097
    564
    MSP
    If it were legislative, it would apply to all OEMs uniformly, clearly that is not the case.
  10. Mendel Leisk
    40,955
    There's a lot of Honda's in our household, never see suspension or bolt rust like this. Maybe galvanizing the frames and better bolt coatings, who knows.
  11. bisco
    51,510
    maybe toyota doesn't want to increase the cost of the car, since the rust never seems to be a safety issue.
  12. eman08
    360
    192
    US
    Looks much better. Sand it all down and undercoat it. All ready for the winner now. 1478561081217.jpg 1478561091276.jpg
    priusrust, ILuvMyPriusToo and bisco like this.
  13. bisco
    51,510
    well done!(y)
    eman08 likes this.
  14. eman08
    360
    192
    US
    i took my dash apart a couple months ago as I notice this weird electric motor rattling sound like a small motor turning back and forth some where behind my steering wheel and the right vent next to the start button. Is there some kinda of pump behind the dash because I sure didn't see one when I took the dash apart behind the steering wheel as all I saw was the power steering computer module? I only hear it with in side the car and no where outside of the car or engine compartment. It also happens while stationary and also when the AC is off. Its like someone rattling a door nob twisting it back and forth. Possibly be the electric steering motor doing that?
    #14 eman08, Nov 7, 2016
  15. bisco
    51,510
    not the brake accumulator?
  16. eman08
    360
    192
    US
    hard to tell as it doesn't effect my steering or driving what so ever. It doesn't it every now and then not every day. just started a new thread about this new topic.
  17. eman08
    360
    192
    US
    Repost from other my other thread. Here is that electric motor noise I was talking about. ignore that brushing sound as its just me moving my phone around. You can hear a rattling back and forth sound behind the dash board more near the shifter. https://drive.google.com/open?id=0B9ZD2aOUG4DaVDJObWRMdzZWOG8
  18. edthefox5
    edthefox5 Senior Member
    10,096
    4,832
    Clearwater, Florida
    That looks really good on the axle there. Lots of work.
    Go to Home Depot and buy a few cans of PB Blaster CSP. Thats Corrosion Stop preventer. Its spray grease that stays where you spray it and does not smell. Hose the suspension down with this product especially the front end. Works great will protect the metal form corrosion and no squeaks or creeks. Catch the door hinges the hood lock the hood hinges the trunk lock and the key lock hole.
    And that noise your hearing is the brake vacuum motor. To replicate it with the car off just push the brake down a few times and it will evoke that noise.
    eman08 likes this.
  19. eman08
    360
    192
    US
    Thanks. I think I figured out that little motor noise as its only audible with inside the car and not the engine compartment. Most def seems to be my servo motor going out. The sound sounds exactly the same in these two videos.
  20. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    I like the job you did on the rust! What did you spray on it? the black....
