PRIUS 2007 RUNS MORE ON ICE, AND HAS GOT ONLY 25MPG
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dxta, Nov 14, 2016.
  1. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    guys.I have got a Prius 2007, with 175, 368mi. Have recently noticed that it runs more o. ICE, than on the electric motors. The MPG is terribly bad(from 46 its down to 25) now.
    There isn't check engine light; no triangle caution sign.
    What do you think coukd be the problem?
    I'm thinking it coukd be the battery, or any of the engine management system.
    Thanks for the help house!
    PS: Sorry, I'm new here.
  2. dolj
    dolj Senior Member
    8,430
    4,285
    Wellington, New Zealand
    Possibly, but you need to read the DTC(s) that the ECUs have logged. Anything else is just a crap shoot that could have you unnecessarily replacing parts that are not the problem.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I am somewhat confused, do you have a 2007 or a 2010 or both?
    There are 3 main batteries in a Prius.
    The Fob battery does not cause mileage issues if it fails, you just can't get in the car. (About $2USD)
    The 12 volt battery can reduce mileage as it fails although rarely more than 5 MPG. at 9 years, it could be on it's last legs. (About $200USD)
    The Hybrid battery is usually long lived, only about 5% of 2007s have failed yet. ($3500 USD)
  4. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    @dolj. Its got no check engine light on the MFD. Just nothing.
  5. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Jimbopalmer. I meant to say the hybrid battery.
    Seems to me, maybe why the ICE keeps running often might be the hybrid battery isn't charged, and that's why the ICE is just running, consuming more fuel.
  6. bisco
    51,843
    welcome! makes sense, but you should have a dtc if it's the hybrid battery.
  7. dolj
    dolj Senior Member
    8,430
    4,285
    Do all the dashboard lights (except the master caution - Red triangle with the ! in the middle) come on if you press the START button once with your foot off the brake?
  8. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    @Jim
    You're right bisco! But the problem is I don't just have a dtx on.
    Bisco! Wanna ask a?????. Must a DTC be thrown to show a hybrid battery is failing?
  9. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Dolj. All of the lights comes on, except the master light. Recently, the ABS light came on
  10. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    What worried me is, why does the ICE runs more than the electric modes, and the 25mpg I get from it?
  11. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Dolj. All the lights come on when the switch bottom is pressed. No master light.
  12. bisco
    51,843
    yes, at least for warranty. i don't recall reading about anyone with a bad battery, who didn't get the red triangle of death.
  13. bisco
    51,843
    there can be many causes for reduced mpg. what would you say you typically were averaging before the reduction?
  14. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Averaging 45mpg
  15. bisco
    51,843
    have you noticed any erratic behavior in the battery meter?
  16. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    I think m
    I think my next plan is to check the plugs, Maf sensor, engine oil levels, etc.
  17. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Not really.
  18. bisco
    51,843
    generally speaking, when the battery is going south, before the triangle of death, the meter fluctuates rapidly from low to high to low, etc.
  19. bisco
    51,843
    so how to explain 25 mpg, or engine running too much? has anything changed recently? tires? driving area? oil? gas? maintenance? accident?
  20. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Would check the fluctuation thing and report to the house.
