Exide Battery Vent Elbow and Tube Install
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Siward, Nov 16, 2016.
Tags:
  1. Siward
    Siward Active Member
    311
    126
    Toronto
    I am thinking of buying a Canadian Tire MotorMaster Eliminator 12V battery which is a rebranded Exide battery. The AGM battery should be better quality than the OEM lead acid. I am trying to figure out how to install it.
    Another battery for the Prius. | Page 2 | PriusChat
    For those who have installed the Exide battery before, how did you install the vent tube? Did you simply remove the OEM elbow and attach the new elbow to the OEM rubber vent tube? Or did you have to replace both the OEM elbow and rubber tube?
  2. Mendel Leisk
    40,467
    Do you have to change anything? I replace our OEM with an Optima, a year back, and just hooked up the original vent tube and elbow. The vent port on the battery was the same size/location.
  3. Siward
    311
    126
    Toronto
    I did my share of googling. The Optima battery reuses the OEM vent elbow, so it is a direct drop in.
    According to the other forum posting shown in the link above, the Exide battery has a smaller elbow opening.
  4. Mendel Leisk
    40,467
    Oh, ok.
    One thing I found: with Toyota's hold-down bracket design, battery height is critical. Even slight variation mess it up, a poor, unaccomodating design. It's fixable with a bit of shimming under battery or washers under the bracket.
  5. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    I think I used the original elbow on my Canadian Tire battery. I had to pry out the yellow plug on the battery. My battery didn't come with an elbow as I recall.
  6. Mendel Leisk
    40,467
    And the Canadian Tire battery is likely rebadged Exide.
  7. Siward
    311
    126
    Toronto
    Yep. My main concern is the vent tube. I wanted to know if I had to buy my own, but I will trust David's post and try to use the OEM elbow. Below is the Exide battery. Previous posts have indicated that the vent elbow hole is smaller.
    Or maybe I can get away with not venting the AGM battery. Does AGM batteries need to be vented?
  8. Mendel Leisk
    40,467
    You'd be ok for a few days anyway, till you sort it out.
  9. David Beale
    5,963
    1,987
    Edmonton Alberta
    If that is your battery in the picture just pull the elbow off the hose and shove the hose on the installed elbow. Save the original elbow "just in case". ;)
  10. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    manufactured in july 2014....??
  11. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
  12. CR94
    CR94 Senior Member
    2,660
    1,149
    Northwestern S.C.
    Top clarify, all AGM batteries, including the original one and the Exide, are a type of lead-acid battery. They have (or don't have, a different debate) equal need for venting.
  13. Mendel Leisk
    40,467
    @Siward Please post if/when your Motomaster is installed, how it went. It's definitely better deal than Toyota OEM right now (they're around $270 last time I check), and maybe $10~20 cheaper than Optima. I put in the latter a bit over a year back, but it seems like Canadian Tire is pretty on the ball with batteries: we put CT battery in our son's Civic, and it was dimensionally exact match, and good CCA from the get go.
    Also..., at least at the store I was at: they had a pro-level digital CCA tester, and were more than willing to hook up the battery I was getting. I had brought along my Solar BA5 tester, but they offered. It showed very good CCA, well above spec, and I verified later with mine.
    #13 Mendel Leisk, Nov 18, 2016
