Child seat behind driver... can I still fold down the rear seats?
Discussion in 'Prius v Accessories and Modifications' started by brek, Nov 20, 2016.
  1. brek
    brek New Member
    maryland
    Looking at a Prius or Prius v. I'm wondering if it's still possible to fold down the 60% side of the rear seats if I have a child seat installed (forward facing) on the 40% side behind the driver. Anyone have any experience with this?
    Thanks.
  2. Air_Boss
    Air_Boss Senior Member
    4,190
    1,177
    New Yawk
    No problem, and no different than a passenger seated behind the driver while the other side of the rear seat is folded flat.
    #2 Air_Boss, Nov 20, 2016
  3. Mendel Leisk
    41,342
    I think your question is more "is it permissible?". Look at it this way: if it's readily done, you didn't modify the seats or interior in anyway, it's doable, then it's fine.
    Unless maybe you're transporting boa constrictors. :whistle:
  4. brek
    brek New Member
    maryland
    Thanks! It's actually a question of space. In my current car (Honda Fit) if I install the seat on the 40% side of the split, it overhangs into the 60% portion, blocking that section from folding down. It could just be a matter of getting a different car seat.
    I'm looking to be able to haul long items (with the front passenger seat folded down as well) without having to remove the child seat every time.
  5. PosauneGuy
    PosauneGuy Member
    123
    91
    California, here I come...
    2025 Prius
    Fold the seat down first, then put the child seat in!
  6. WaterDragon
    WaterDragon Junior Member
    Palo Alto, CA
    2013 Prius v wagon
    I have a big car seat, the Chicco NextFit Zip rear facing on the 40% side and can easily fold up and down the 60% side with no problems, so unless you have a seat bigger than the NextFit Zip, you will have no problem.
    Bmr4life likes this.
