I need an oil dipstick.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Godiva, Jun 9, 2006.
  1. Godiva
    Godiva AmeriKan Citizen
    10,339
    The loop broke off my oil dipstick the last time I went to check my oil. Now maybe the service department bent and cracked it so that when I went to pull it just broke off in my hand, but I can't prove it. So now I have to check my oil by pulling it out with a pair of pliers.
    It's not exactly a common salvage item so I was wondering if anyone who was salvaging a Prius happened to have one for a nominal fee?
  2. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    <div class='quotetop'>QUOTE(Godiva @ Jun 9 2006, 03:08 PM) [snapback]268888[/snapback]</div>
    You might try here:
    I have many prius parts.
    see my website or contact me...steve
    autobeyours.com
    or http://www.autobeyours.com/PriusParts.htm
    A post from this thread on Prius Chat: http://priuschat.com/Power-split-device-innards-t19463.html
    Everything we need is here.
  3. Godiva
    10,339
    You don't have an oil dipstick listed. But I'll bet there's one in one of those wrecked Prii.
    Unfortunately I can't come to your yard to look for myself. I'm in California.
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I suggest you don't actually need a Prius dip stick, one from any Toyota or Scion that uses the 1.5 L engine should work. Just hold it up next to the old one and make sure the part that goes down in the engine is the correct length.
