Winter is coming... Modifications and questions...
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Nougatti, Oct 13, 2016.
  1. Nougatti
    Nougatti Member
    119
    59
    Norway
    I just did a thing!
    We all know winter sucks, and having a PiP you wanna NOT turn on that gasoline engine to defrost the windshield. I haven't invested in a cabin heater to compliment my block heater yet, so I use a car cover.
    However, the car is often parked at not-my-house, so the cover needs to be carried along when I get in and drive it. This presents a problem since it's covered in frost and thawing it inside the car will transport moisture inside which will freeze the INSIDE of the windows, so here is my genious - if not slightly more power consuming - solution:
    I fixed fastening straps to the rear roof bar with screws, and can simply roll the cover into a neat little roll from both ends and strap it tight with the straps. It's got more air resistance, but my daily driving isn't fast or at the edge of my EV range anyway.
    Rebound, bisco and mrbigh like this.
  2. Nougatti
    Nougatti Member
    119
    59
    Norway
    Question: If I were to invest in an electric wall-powered cabin heater from DEFA to compliment my previously installed block heater, I have the option to add a trickle charger into the mix, which I've heard might be a good idea on these cars during winter times.
    Does this charger have to be connected to the physical battery in the back, or can I connect it to the "battery ports" at the front used for jump starts? The latter would be so much easier since the plug where the power comes in, sits in the front bumper.
    mrbigh likes this.
  3. bisco
    51,518
    the front jump point will be fine, but connecting it daily at the fuse box might be a pain.
  4. Nougatti
    Nougatti Member
    119
    59
    Norway
    If I use a DEFA system, it will just be connected in parallel to the heater anyway and stay permanently connected. The whole system has an in-plug in the front bumper. Why the PiP doesn't trickle the 12V while charging is beyond me.
  5. Air_Boss
    Air_Boss Senior Member
    4,161
    1,166
    New Yawk
    Nice drag chute you got there.... Beware unintended deployment.
  6. bisco
    51,518
    it does trickle the 12v while being charged.
  7. Nougatti
    Nougatti Member
    119
    59
    Norway
    Oh! Then that solves that :)
  8. Nougatti
    Nougatti Member
    119
    59
    Norway
    Haha, I had the same solution on my old Corolla back in the day :) Worked a treat!
    Never drove faster than 80 km/h with it on though. And will never drive long haul with it on the Prius either.
  9. Nougatti
    Nougatti Member
    119
    59
    Norway
    Update: It's getting ever colder, but now I've started using our newly installed (last week) DEFA cabin heater. No more icy windshield :D
    Also, this might seem crazy, but the projected EV range at the beginning of each trip is rising now that the interior is warm while charging. I definitely think the cabin heater increases the charged capacity of the battery pack!
  10. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    Yes, but I think you will find that the trickle charge stops once the hybrid battery charge is complete.
  11. Pluggo
    608
    533
    Speaking of cabin heaters, I tried this little 170w/250w “personal” ceramic heater from Home Depot. Very gentle heat and equipped with a tip-over switch, but it only raised the interior temperature about 10 degrees F after an hour and a half. That could be enough to help many people keep a clear windshield and reduce interior humidity.
  12. bisco
    51,518
    that might work well on the dash if it will stay upright. does it plug into the 12v socket?
  13. Nougatti
    Nougatti Member
    119
    59
    Norway
    You guys gotta use mains powered heaters... 12V doesn't do shit :p
    My cabin heater is 1900 W btw :p
    It and the block heater connect to the mains via a socket in the front bumper. Image1480704929.919397.jpg
    The interior stays warm at least till the EV range runs out.
    #13 Nougatti, Dec 2, 2016
    Rebound likes this.
  14. Pluggo
    608
    533
    Works off house current and, yes, it does stand nicely on the dash. I didn't want to mention that because I was afraid someone might have a hissy fit and claim it will crack the windshield. I really don't think it gets that hot and the fan helps prevent heat concentration. Picture a 170w light-bulb a foot away from the glass. Funny thing, the warning sticker is exactly the same one you would see on a heater with 10 times the power: keep "furnishings at least 3 ft from the front of the heater and away from the sides and rear."
  15. Nougatti
    Nougatti Member
    119
    59
    Norway
    The heat generated from the engine is MUCH MUCH hotter than your little fan, anyway. Why wouldn't THAT crack the windshield on a cold day?
  16. Pluggo
    608
    533
    Excellent point. That should clear up any lingering concerns.
  17. Air_Boss
    4,161
    1,166
    New Yawk
    How do you figure? Engine coolant isn't going to be much over 180-190 degrees under normal circumstances, meaning blended airflow heated by engine coolant will be less than that temperature, while electrical resistance heaters and fans often produce much hotter airflow.
  18. Pluggo
    608
    533
    Some data points: the 250 watt (850 BTU/hr) heater when aimed directly at a digital thermometer 10 inches away raised the temperature to 92 F after 20 minutes and then held steady. Moving closer, at three inches the temperature went to 121 F after 20 minutes and stayed there. I would not hesitate to use a low-powered heater like this one on my windshield. In actual practice the heater would be as far back on the dash as possible so the stream of air would blow against a wide section of the windshield.
  19. Nougatti
    Nougatti Member
    119
    59
    Norway
    Another thing is that the outside of the windshield is going to get a continuous blast of cold air while driving, at say -20'C, with the same blast of hot air from the vents on the other side. The temperature difference would be yuuuge (to quote Donald Trump). The car is definitely designed for it.
    Now, someone fetch a thermometer and measure the exit air of the vents at "full steam".
    iPhone ?
  20. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    It's not crazy at all: Li-ion batteries work best at more or less the same temperatures that humans find comfortable. The batteries are heated or cooled via the cabin in the PIP - you can see the two vents on the sides of the rear seats. I think the Leaf and other EVs actually have a battery heater for cold climates (may be optional depending on region).
    Is it actually improving your effective range, and not just the estimation?
