Locations of airbags deployment
Discussion in 'Gen 3 Prius Main Forum' started by Miyamoto, Dec 7, 2016.
  1. Miyamoto
    Miyamoto Junior Member
    Centreville, VA
    Hi all,
    I know my 2011 prius model 3 has airbags all around our cabin. I assume when activated, one will come out directly from center of the steering wheel and several from the curtain side, but where does it come out of on the front passenger side? I am in the process of finding a suitable location for a cell phone holder and I don't want to put in a location that would not interfere in the deployment of the bags; I fear the bags could propel the phone holder and injure the occupants. Are the spots in the interior that I should not place the cell phone holder, i.e, some where on the dash,etc.?
    Thanks!
  2. ChapmanF
    18,076
    You're absolutely right, it's hard to find any place near the driver and passenger where you can be sure it's safe to mount hard objects that you don't want to be launched by the airbags.
    The passenger front bag will erupt right through the top of the dash, pretty much centrally above the glove boxes. It's a large bag, and of course it expands back toward the seat and out to the sides.
    -Chap
  3. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    If you stay on the console between the seats you will be "safe" though your holder can still become a projectile on its own. Vent holders ARE NOT safe! In a high speed collision even "small" objects are dangerous.
    The bags come out from: (drivers side)centre of steering wheel, under the dash, above door, outside seat bolster
    (passenger side) same without the under dash bag, steering wheel bag comes out from the dash and is very large
    (rear)above door only
    If you can find the brochure from Toyota it actually shows all the bags deployed.
    (mounts podium) The safest place for a cellphone is in storage and on "ignore" when driving. ALL studies have shown "hands free" is just as dangerous as holding a cellphone while driving. My experience has shown the same, and I'm more capable than any of you! ;)
    (dismounts podium)
    I defer judgement re GPS direction from a cellphone. It can be safer knowing where to turn and it can be more dangerous trying to operate the GPS application while driving.
    #3 David Beale, Dec 8, 2016
  4. AzWxGuy
    AzWxGuy Weather Guy
    1,051
    536
    Tucson, AZ
    2021 Prius
    Page 14 has a side view. An overhead would have been nicer for your purposes.
    PriusNeckBeard likes this.
  5. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    So , my cell phone mount is to the left of the steering wheel. It's a suction mount to the windshield, with a horizontal bar extending towards the driver, terminating with a sort of squeezing rectangle that faces the driver, to which the phone attaches.
    Is this safe? It seems so..
    The bar is about 4-5" long.
  6. David Beale
    5,963
    1,988
    Edmonton Alberta
    I don't think any of the bags come close to the windshield.
    In some states it's illegal to attach anything to the windshield (California, for example). The reason is those objects can cause the windshield to fail in a crash earlier than it would normally. The windshield of a modern car is part of the "structure" and is required to be in "good condition" (no cracks) for the crash worthiness of the vehicle to be predictable (safe).
    With that in mind I've used the dash surface for various things such as an Amateur radio control head, Scangauge, and even a GPS, all mounted ahead of where the bags move. I've used 3M stick on velcro. Because the cords go back towards the driver, in a crash the device -usually- wouldn't hit the windshield - the cords would slow or stop it. That was the theory anyway. Thankfully I never got the "crash test" to prove it.
    Something to keep in mind. No matter what you do, you probably can't predict -exactly- what will happen in a crash. I know the engineers aren't successful every time. I've seen "tweaking" of interior layouts after the -first- actual crash test.
  7. AzWxGuy
    AzWxGuy Weather Guy
    1,051
    536
    Tucson, AZ
    2021 Prius
    Here is another picture gleaned from a Google image search. It shows how far over to the left the passenger side bag comes. Just about to the center-left vent. The space forward of the steering wheel appears to be "open". I am in total agreement with Mr. Beale though in regard to placement of devices within the cabin for convenience. You will not be able to safely stow that device in the split second before disaster.
  8. belladorje
    belladorje New Member
    eugene
