Gas gauge
Discussion in 'Gen 2 Prius Main Forum' started by amjohnson, Dec 14, 2016.
  1. amjohnson
    amjohnson Junior Member
    77
    US
    Okay I know that there are tons of forums and threads about the gas gauge but I live in Minnesota the temp is 5 above with the windchill making it feel like 20 below I just put in 7 gallons give or take a little and it won't show on my gas gauge that it's completely full why is that I read about calibrating but I don't know if I really need to do that can someone help me out 1481759982942.jpg
  2. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    I wouldn't panic just yet. It may just be that with the cold affecting everything (bladder flexibility, car sensors, gas station equipment, etc.) you really didn't get it all the way filled. You put in 7 gallons but maybe under normal conditions it might have taken 8 or 9.
    See how things read the next time you fill up. If the gauge still seems to be a problem then consider a re-calibration it at that time.
  3. cipsaz187
    cipsaz187 Member
    150
    42
    It happens this on my wife's 2009 as well. Its probably due to a cold weather or gas pump, but most likely the bladder is acting up. You shouldn't worry about it.
  4. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Situation normal. Especially for colder climates/times of the year with this vintage Pri. Don't try and force more fuel in, stop at the click.
  5. amjohnson
    77
    US
    Good to know just filled up again today because we're in a snowstorm want to make sure I had gas had one bar below a half a tank put 5 gallons in still doesn't feel up to the last bar it is 14 above for the temperature
