Key fob gradually stopped working... $4-500 for repair or DIY?
Discussion in 'Gen 2 Prius Technical Discussion' started by Edwardius, Dec 15, 2016.
Tags:
  1. Edwardius
    Edwardius New Member
    New Jersey
    Hi all,
    My 08 Prius has a key fob that gradually stopped working over the course of a year. It kept losing more and more range until SKS died, then the fob button unlock/lock wouldn't work either. I now have to use the pull-out key to unlock (which is a pain in winter because everything freezes and makes it hard to turn).
    Dealer charged $99 for a diagnostic and then said $4-500 to reprogram the system or something (I can't remember, it was a while ago.) At the time I was short on cash and decided not to, but now I'd like to.
    Any way I could DIY? I don't think chicken dance would work because I would need to have a working smart key right? Just looking to save $$ if possible.
    Thank you for reading.
  2. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
    Get a second opinion at a professional locksmith (not a place that just duplicates metal keys).
    priuscatprimeguy likes this.
  3. bisco
    51,973
    welcome! do you only have one? did you test the battery voltage, as well as your 12 volt battery?
  4. ChapmanF
    18,242
    The battery in your fob ought to be closer to the $4 end of that range. :)
    -Chap
  5. JC91006
    JC91006 Senior Member
    16,769
    8,567
    Dealer diagnostics? Did they suggest a new battery beforehand?
  6. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Welcome to PriusChat!
    See my previous comments on similar threads. The SKS on my 2009 Gen II started getting very flakey, and to make a long story short, the problem was the 12V AuxBattery (5+ years old) was starting to fail. Perform a load-test on your AuxBat, you might be surprised! Good luck!
