How I got 6 quarts out of....
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by douglasjre, Dec 14, 2016.
Tags:
  1. douglasjre
    douglasjre Senior Member
    2,181
    719
    Null, NL
    Last time I did an oil change with the engine hot I put four courts in. Between oil changes I kept the oil at the full line on the dipstick. The last time I did an oil change I ran the engine till it was hot before draining it. To fill it back up it only took 4 quarts . This time I drained the oil with a cold engine in the morning. 6 quarts came out. I put 4 quarts back in and ran the engine but it barely registered on the dipstick. I had to add two more quarts to get it back up to the full line. You still there always gets changed when I change the oil and not at any other time.
    Doubtful of why this was happening I poured the contents of the drain pan into a 5-quart jug and still had nearly a quart in the drain pan. What are your thoughts?
  2. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    odd /
    maybe someone (former owner, automotive shop....) switched the dipstick /
    since how many miles you're driving with six quarts?
  3. bisco
    51,961
    what about the fliter?
  4. JC91006
    JC91006 Senior Member
    16,769
    8,567
    You shouldn't have more than you put in, unless you're leaking coolant into the engine through the head gasket.
    The engine can burn oil, which will give you less oil than you put in. Never more.
    Raytheeagle likes this.
  5. StarCaller
    1,277
    729
    he put the correct amount in & then kept filling up until the reading on the dipstick was right /
    douglasjre likes this.
  6. JC91006
    16,769
    8,567
    I can't imagine this engine would work with 6qts of oil
  7. douglasjre
    2,181
    719
    Null, NL
    Blackstone says the oil is still good and has no water
  8. douglasjre
    2,181
    719
    Null, NL
    50k. 6 quarts also came out and I checked w my friend's Prius for the correct dipstick. I have the correct one
  9. JC91006
    16,769
    8,567
    You must have gotten the prius V8, that one holds more oil.
    You already have gotten Blackstone report on this? That's pretty fast
  10. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Leave to the professionals to change oil
  11. bisco
    51,961
    yes, take it to jiffy lube, they'll put in 8 quarts for you, then leave the drain plug loose.
  12. Eastside
    Eastside Member
    129
    82
    NorthVirginia
    On that note, at my last JiffyLube visit I provided a Toyota filter and said ..." just change the oil and use this Toyota filter. Don't check the air filters."
    They ignored this and pulled both the air filter and the cabin air filter; and took both over to the Foreman, i.e. salesman. The salesman started to tell me about needing new air filters. Sigh, I just changed those two months ago and they couldn't need replacing yet .
    Your experience ?
    Bham_prius likes this.
  13. douglasjre
    2,181
    719
    Null, NL
    I get two quarts more out when changing the oil on a cold engine that hasn't been started in 8 hours than when I run it first.
  14. StarCaller
    1,277
    729
    now that makes it REALLY odd ////
  15. tankyuong
    1,555
    661
    Central MO
    I don't consider jiffy professional
  16. JC91006
    16,769
    8,567
    I know they legalized marijuana in some states, so best not to do oil changes afterward. Hard to keep track of how much you actually put in
    Or whatever measurement tool is used is not measuring correctly
    Raytheeagle and bisco like this.
  17. Kenny94945
    Kenny94945 Active Member
    850
    426
    Sausalito
    2016 Prius v wagon
    Fascinating.
    I could understand once the engine is started oil goes to the valve train, piping, journals etc.
    So draining hot there remains oil in cavities of the engine and not draining down.
    Draining cold, the oil had time to revert/ drain back to the oil pan.
    So I guess my first question is upon a complete engine rebuild how much oil should be added?
    If dip stick is correct, then just follow the oil change directions and verify the level on the stick.
    Anyway just a comment.
  18. qdllc
    qdllc Senior Member
    1,377
    400
    This sounds most likely.
    Most engine fill specs are conservative. You can safely run with much less and you won't do damage with significantly more. It could have gone bad, but it likely did not.
    The tech manual (if not the driver's manual) should specify how much oil goes in after the motor is drained. One figure if just changing the oil. Another figure if you also replace the filter (as it holds X amount of oil if not removed).
  19. bisco
    51,961
    i demand a video, showing complete drain, refill, drain and measurements!:p
    Rebound and Raytheeagle like this.
  20. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    • Why? It's not necessary and doesn't contribute to the thread.
    You're a troll. Go to the VW forum.
    StarCaller likes this.
