Software update?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SarahfromMA, Dec 15, 2016.
  1. SarahfromMA
    SarahfromMA Junior Member
    Northampton, MA
    Newbie here and first post!
    My mechanic just did a software update on our 2007 Prius.
    What is the purpose of that? It was $97.
    Hope I didn't get ripped off. They are very trustworthy.
    Thank you!
  2. SarahfromMA
    Northampton, MA
    Sorry, just reread the bill and it says update ECM calibration files.
    Can't find much info about that one!
  3. Prodigyplace
    12,526
    11,747
    Central Virginia
    SarahfromMA likes this.
  4. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    ECM ! Electronic counter measures. The mind boggles. :ROFLMAO:
  5. Prodigyplace
    12,526
    11,747
    Central Virginia
    ECM - Engine Control Module. The computer that controls the engine air/fuel mixture and which provides OBD-II diagnostic codes.
    From PriusChat Glossary | PriusChat
    Too many TLA (three Letter Acronyms):eek:
    Everybody reads the Newbie stickies, right? :LOL:
    RCO likes this.
  6. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Well, we are sorta moon's still aren't we? :sneaky:
  7. Prodigyplace
    12,526
    11,747
    Central Virginia
    Moo
    moon's ? Is that a UK term?
    RCO likes this.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Only when the flippin' autocorrect scrambled NOOB'S. :ROFLMAO::ROFLMAO:
    bisco and Prodigyplace like this.
  9. Prodigyplace
    12,526
    11,747
    Central Virginia
    RCO likes this.
  10. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Sounds reasonable. There are maybe a dozen computers running everything, and all (most?) can have software upgrades. My 2006 has never had any calibration updates, which probably means that something isn't running as well as it could.
  11. Tideland Prius
    16,547
    If it's a software update relating to the ECU flash, why were you charged for it?
    Shouldn't the dealer charge Toyota since it's a recall?
    Prodigyplace and RCO like this.
  12. ChapmanF
    18,057
    As with other stuff in the car, what I'd guess is that not every improvement counts as a recall.
    Generally, something will get the recall treatment if the unfixed condition is determined to be unsafe.
    I think some calibration versions go with specific other changes. For example, the Gen 3 EGR service bulletin, T-SB-0027-16, involves both replacing the EGR valve with an updated part, and updating the ECM calibration. I notice I don't have the newer calibration yet, but that's probably as it should be, since it may only make sense with the newer valve. That's an example of a TSB that is being handled as a free warranty extension out to a certain time/mileage, but after that, there would be a charge.
    -Chap
    RCO likes this.
  13. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Presumably you took the car to the mechanic to fix something. What was it, and did it get fixed?
  14. bisco
    51,837
    check engine light. check her 'other post'.:rolleyes:
