Front windshield wipers not working
Discussion in 'Newbie Forum' started by Montyprius, Dec 21, 2016.
  1. Montyprius
    Montyprius New Member
    I just purchased a 2011 Prius and when I went to turn on the Windshield wipers they did not work. But when I manually pushed up on the stick they worked. Do I need a new motor or is this a fuse issue?
  2. ChapmanF
    17,013
    How many clicks down did you push the stick when you tried to turn them on?
    -Chap
  3. Montyprius
    All three clicks, slow medium fast. They all don't work. It only works when I manually push up on the stick.
  4. ChapmanF
    17,013
    I suspect the wiper switch itself, or the wiring between the switch and the Body ECU, maybe a connector partly dislodged if there's been work done in either area. Motor and power seem ok if an upward push works.
    -Chap
    RCO likes this.
  5. Montyprius
    OK, thanks for the information.You don't think it could be a fuse?
  6. ChapmanF
    17,013
    Everybody wants every problem to be a fuse, but I strongly doubt it in this case, because you have seen the motor operate when you push the stalk up.
    Anyway, it seems like the usual reason everybody wants every problem to be a fuse is that it seems like an easy explanation, which it really isn't. Supposing you did find a blown fuse, what you'd have is a problem that blew the fuse, and you wouldn't have found it yet. :)
    -Chap
    RCO likes this.
  7. Montyprius
    Thanks Chap for the information and your help
    RCO likes this.
