Theft of valuables in Prius
Discussion in 'Gen 3 Prius Main Forum' started by nudriver, Dec 30, 2016.
  1. nudriver
    nudriver Member
    267
    28
    los angeles
    Last night I discovered that the storage box next to the drivers seat had been looted. Fortunately I didn't have anything of great value in there, but there was no sign of forced entry and I can't imagine leaving my door unlocked. This happened on my driveway and I am wondering how easy it may be to pick the lock of the driver's door, the only one that has a key slot. Also, is there a lining inside the storage compartment? I can't remember but now it looks strange that the bolts are visible at the bottom of it.
  2. JC91006
    JC91006 Senior Member
    16,772
    8,567
    Yes there's a lining.
    Yikes Los Angeles, my neck of the woods
  3. nudriver
    nudriver Member
    267
    28
    los angeles
    What does the lining look like?
  4. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
    The simplest answer is usually the correct one. BTDT and lost a cheap trac-fone.
  5. Kenny94945
    Kenny94945 Active Member
    851
    427
    Sausalito
    2016 Prius v wagon
    Only the driver door pocket ransacked?
    Not the glove box or center console?
    FWIW I venture to say you left unlocked or better half cleaned the car?
    Yet I guess it could have been picked, slim jim-med, etc, yet no alarm?
    Good luck in discovery of your mystery.
  6. bisco
    52,001
    there are also thieves, especially in cali, who can use a machine to steal your fob code or something when you lock the car, then use it to unlock, after you go in the house.
  7. nudriver
    nudriver Member
    267
    28
    los angeles
    It was actually the center console. Now I have discovered they stole a couple other items including my garage door opener! Someone must have remotely broken in. Why they picked my car I have no idea.
  8. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    There was news reports on TV recently, about the 2017 Camry being easily unlocked by some type of remote device. Other cars as well. The criminals are always a step ahead in technology.
    Also, there have been several reports by Gen4 Prius owners finding their car unlocked. Myself included. It's a mystery. I'm positive I locked it, because I heard the beep. When I come out the next morning I find it unlocked.
    My 2016 Prius is more strange, odd, and weird than any other car I've ever owned. The only thing good about it is the gas mileage!
  9. bisco
    52,001
    disable your garage door opener until you can change the code.
    Felt and The Electric Me like this.
  10. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    They can target you again.
    Why wouldn't they?
    Don't put anything of value in the car for three months, imo. Including the new garage door opener you'll be getting.
    Maybe put that under the front seat..
    Maybe.
  11. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    A thin sheet of rubbery grey material. It just sits there.
  12. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    I hate to break it to you, but it's also possible that you forgot to lock the doors. If they'd hacked your locks, they could have driven away with the car. Very quietly, I might add.
  13. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    Actually, the problem with the Prius keyfobs is well known.
    Setup: Your fob, somewhere within radio range. This mean within a couple of hundred years of your car.
    The crook: An nice person with a more or less standard thief box. Available on-line.
    What happens: The weak radio signal from the Prius is picked up by the thief box and rebroadcast at much higher power. This is picked up by the fob. It thinks it's close to the car (Big Signal!) and broadcasts the signal back to the car.
    Normally, this signal would be too weak, given the distance, to unlock the doors. However, the thief box has a second receiver/transmitter that is sensitive enough to pick up the fob signal and rebroadcast it to the car.
    Crook grabs the door handle: The car opens.
    This has been reported in the NY Times, where a reporter watched a pair of teens break into his locked car, out on the street, with his fob on the kitchen windowsill, where he kept it. He ran out the door, they noticed, and took off.
    My car's in my garage, so I don't worry about it too much. But street parking, at home or in a business district, can get one in trouble. At work, me and my fob are far enough away from the car so this trick won't work.
    Only known solution: Putting your fob in an electromagnetic enclosure. Little tin can, good ESD bag, etc. But then you have to take the fob out when you want to use it, which kind of wrecks the convenience.
    The car START button mechanism is supposedly different: I've heard of cars getting unlocked, but not driven away. Which would explain why your stuff was riffled through, but the car itself wasn't stolen.
    KBeck
  14. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    Or, turn off the SKS, so the doors don't unlock without pressing the button on the fob.
  15. Mendel Leisk
    41,522
    I measured the centre console inlay on our 2010, made a sketch:
    (There's an additional, large radius fillet at the shallow deflection along the sides, but just doing a sharp corner at the 2" mark produces about the same outline.
  16. PriusNeckBeard
    376
    211
    Cincinnati
    Hey everybody
    True or not true?
  17. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
  18. ETC(SS)
    7,184
    It doesn't sound preposterous, but it does sound a little complicated when a slim-jim or just pulling on 100 door handles is much more effective.
    If I were the looters and hacked the FOB, I would have driven the car a few blocks away and taken my time and completely ransacked the car - or just stolen it outright.
    Look for scratches in the window gasket or admit to yourself that you might just have left the door open.
  19. BZzap!
    BZzap! Senior Member
    1,607
    878
    My neighbor across the street had her car broken into just the other night. I should say, she had it illegally entered, as the doors were unlocked. The typical M.O. of the run of the mill tweeker is to just walk down the street and try door handles. It's always a good habit to physically check the doors to make certain they are locked. Just about everyone has inadvertently left their car unlocked at one time or another. Unfortunately, stealing other people's property is just a way of life for a large population of our society.
  20. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Prius She Wrote....
    We can debate forever "how" the crime happened...and we really won't know. Thieves can gain access in any manner from simply opening an unlocked door....to a uncountable number of more complicated maneuvers.
    But I strongly second the advice to disable your garage door until you get the code changed.
    Obviously people steal the remotes to gain access to your garage....and then you house.
    At this point securing everything else would be my #1 priority.
