Warning beeper sounds nothing is on then dead battery
Discussion in 'Gen 2 Prius Technical Discussion' started by Cindy A, Jan 6, 2017.
  1. Cindy A
    Cindy A New Member
    Viroqua Wi.
    When I shut car off a warning beeper sounds . No warning symbols just beeper. Everything is off. When I go to start it later the battery is dead. What is this mystery beeper trying to tell me
  2. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Headlights ?
  3. bisco
    51,837
    welcome!
    low fob or 12 volt battery.
  4. Cindy A
    Cindy A New Member
    Viroqua Wi.
    Nope they're off.
  5. Cindy A
    Cindy A New Member
    Viroqua Wi.
    Not the fob the battery in that is pretty new. I'll have the 12 volt checked out .Thanks
  6. bisco
    51,837
    all the best!(y)
  7. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    The fob has a red LED that should blink when you press a button. The the fob blinks, it's something else like the 12V battery. If that's the original 12V battery on a 2008, I think we have a Bingo...
    Data Daedalus likes this.
  8. Cindy A
    Cindy A New Member
    Viroqua Wi.
    I hope you're right I hope it's something that simple. I will check on it.
  9. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    Sounds about right. I only ever experienced those shutdown beeps under one of those circumstances. The 12 volt battery. T'was replaced, problem resolved.
    iPhone ?
