Prius 2011 monitor black after interior detailing
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dlrnmsn, Jan 7, 2017.
  1. dlrnmsn
    dlrnmsn New Member
    Azusa, California
    Took my 2011 Prius to dealership for airbag recall. I was offered interior detailing and accepted. Now the monitor is black yet the radio works and buttons can be used if you remember where they are. Toyota dealership denies wrong doing and insists detailing would not cause the problem. Unable to use back up camera. Now being told the car will have to be sent out for fixing because they do not do it. Can cost over 3,000. Help!!
  2. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    This has happened before when liquid has been sprayed on the screen and gets into the electronics.
  3. dlrnmsn
    dlrnmsn New Member
    Azusa, California
  4. dlrnmsn
    dlrnmsn New Member
    Azusa, California
    Toyota dealership, after they did the detailing, says it is a coincidence and detailing had nothing t o do with it. How do I convince them it was the detailing that caused the monitor to go black
  5. Mendel Leisk
    41,457
    Tell them you're going to check directly with Toyota corporate.
  6. nate16
    nate16 Junior Member
    40
    peabody, ma
    My 2011 unit has the same problem. Backlight is dead, touch doesnt work but with an LED I can see the screen. Waiting for a part to come in from china to attempt fixing it. I'll keep you posted on the fix. The part costs 72$ for the new screen driver board.
