Driver's door Smart key sometimes fails
Discussion in 'Gen 4 Prius Main Forum' started by dslomer64, Jan 9, 2017.
  1. Prodigyplace
    12,465
    11,712
    Central Virginia
    dslomer64 likes this.
  2. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    On the Gen 4 you just press a button on the fob to re-activate it (see the last line on my post).
  3. bisco
    51,562
    that's how gen 3 is also, touch sensitive. when i have gloves on, sometimes it works, sometimes it doesn't. just like the touchscreen.
  4. Prodigyplace
    12,465
    11,712
    Central Virginia
    I have had no issues with mine yet.
  5. bisco
    51,562
    works all the time with winter gloves on?
  6. Prodigyplace
    12,465
    11,712
    Central Virginia
    Yup, so far.
    You need to get one when you get back from Florida.
  7. bisco
    51,562
    they must have improved the sensor. does your touchscreen work with gloves as well?
  8. Prodigyplace
    12,465
    11,712
    Central Virginia
    I do not use my touchscreen enough to give an answer to that. It is getting warm enough right now that I will not be wearing gloves for a while.
  9. bisco
    51,562
    50 today, why go to florida?
  10. Prodigyplace
    12,465
    11,712
    Central Virginia
    You got 50 in Boston? 48 right now in Virginia with high of 64 tomorrow.
  11. bisco
    51,562
    high of 50, 37 now. great to be able to get out for a walk and such.
    Prodigyplace likes this.
  12. PriQ
    PriQ CT+iQ
    377
    113
    Europe
    Older Toyota with the same system. The manual says the same as the G4.
  13. Prodigyplace
    12,465
    11,712
    Central Virginia
    Some lower trim G4 like my Trim Two is just the driver's door SKS. Some other trims have all door SKS, I believe.
  14. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    No gloves or with gloves, same result.
    Gen 2 (2006) and Gen 4 (2017)
  15. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    The car is brand new. Just began using (just found) second fob.
  16. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    3 door. So... ?
  17. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    Thanks, but none of these apply.
  18. bisco
    51,562
    how often is it happening? do you think you can reproduce it for the dealer?
  19. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    Good point but without removing gloves, hatch and passenger door open fine.
  20. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    Locking hasn't failed yet
