LED headlights
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Noobprius, Jan 16, 2017.
  1. Noobprius
    Noobprius Junior Member
    43
    US
    I have a 2006 prius with normal halogen headlights. Is it possible to just buy LED lights and put them in?
    Rafael Juarez and iron-icman like this.
  2. xliderider
    xliderider Senior Member
    8,040
    3,212
    Honolulu, HI
    It's possible, but don't expect them to be very good at actually lighting the road well.
    Noobprius likes this.
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    I recently installed a set LED lights into my wife's Altima. 80W each led light assembly...160W total..16,000lm total output... they are super bright compared to halogen. But still don't have the same brightness as HID. But because her assembly uses her high beam as her DRL, HID wasn't an option. LED allowed for a lower voltage allowing the DRL to function as designed and still functioned as high beam at full wattage. HID doesn't function if at all unless the correct voltage is presented so it wasn't an option.
  4. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    If you were to put a similar set into a halogen or oem prius HID headlight assembly, the light scatter would be awful.. blinding oncoming traffic. Nothing beats a true HID projector retrofit to date for our Gen2...when there is... I'll upgrade.. until then...
    Old photos from when i was still in San Diego...
    Br4zuc4 and Noobprius like this.
  5. Noobprius
    43
    US
    That's a pretty sweet looking prius. I love that color...wish I had it...
  6. Noobprius
    43
    US
  7. xliderider
    8,040
    3,212
    Honolulu, HI
    I wonder how these aftermarket projectors are?
    They use H9 65w halogen bulbs, so they should be pretty bright.
  8. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    It was a retrofit I did...
    MagnusAG99 and SFO like this.
  9. Noobprius
    43
    US
  10. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    You will find several threads on those crappy eBay projectors. They look "ok" but like most mass produced projector headlights, the lack in quality and clarity of the lens as well, the engineering of the projector beam lack good focus of light pattern.
    Their Low beam output
    and High beam
    VS
    @USCBWSR - Evan's Acura RL Retrofit Headlight Retrofit V2 | PriusChat
    and
    #10 Justdidit, Jan 17, 2017
    SFO likes this.
  11. xliderider
    8,040
    3,212
    Honolulu, HI
    Still, the cutoffs of the projector lowbeams are better than reflector type lights.
  12. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    ^-- I'd agree with that..
  13. oil_burner
    oil_burner Active Member
    249
    126
    Has anyone dropped a LED bulb into a stock halogen reflector and can comment on the beam pattern? I really want to do this to my 06 which has halogens to get some brighter output.
    Yes I am aware how great some people think retrofits are. I have FX-R projectors in one of my cars and some S2000 projectors in another with 50W HID's. The problem is after spending around $1000 to retrofit both those cars I have a great sharp cutoff and even beam pattern, great light. I can't read any dam street signs at night without high beaming them. I have trouble reading overhead signs on the freeway too. The cutoff is too sharp and no light makes it up. I prefer a bit of scatter so I can actually see things in front of me not just the pavement.
    SFO likes this.
  14. planetaire
    planetaire Plug in 20 kWh 85 km/h or > 208km range
    190
    139
    France
  15. SERGEJ GONCARENKO
    SERGEJ GONCARENKO Junior Member
    IRL
    3-4 months ago installed these 5th gen LUMILED H4 bulbs from aliexpress (can't post a link yet, as i am new user) 20161129_154449.jpg 20161129_165402.jpg
    Bright, light up road (wet as well) perfectly. When pointing to the wall, can see curved edge. Have to say, curve is not 100% but clearly visible. Also I had to adjust position of the headlights to the 2nd (thumb wheel position).
    Never had any complaints (blinking) from other drivers. But didn't go through NCT (MOT) yet.
    SFO likes this.
  16. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    I'm so glad to see this thread I was using a brighter halogen in my 08 Prius, but they wouldn't last long so I changed them to LED bulbs. Here is the thing I changed the housings at the same time as well. So I don't have any before pictures but here is what it looks like now. I can't get the height adjusted correctly and the pattern does seem a bit scattered. I cut up my rubber cover to make them fit and every thing I really don't know what I want to do now 20170303_213121.jpg 20170303_213134.jpg 20170305_195538_001.jpg
  17. Abdulaziz_Barham
    Abdulaziz_Barham Junior Member
    68
    Jordan-Amman
    Three Touring
    I have the same problem with lights ( xenon or halogen or led ) my car 2008 full xenon headlights originally but didn't have the OEM parts .. so the are not bright enough.. I don't know what to do since the OEM so expensive...
  18. Abdulaziz_Barham
    68
    Jordan-Amman
    Three Touring
    Any advice please.. l forgot to mention that xenon headlights are not allowed in Jordan as well.
  19. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    How does that law work? No Xenon but LED are allowed? Not even Xenon projection headlights?
    SFO and valde3 like this.
  20. Toppcat
    Toppcat Member
    223
    69
    Northern California
    Oem reflector headlamps are design around a halogen bulb, any others may not work properly! A professional Hid retrofit will produce best results. I have a set of ANZo on a dodge ram pickup they are good but don't produce a sharp clear output as a moramoto d s2 retrofit system I done on a subaru xv.
    hyp3rmil3r likes this.
