Interesting Info in SSC 60C on Prius Locations
Discussion in 'Gen 2 Prius Main Forum' started by Tempus, Jun 15, 2006.
  1. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Looking at SSC 60C, there's a table by state showing the affected number of cars.
    This is the first info I've seen seeing a multi-year summary of actual Prius locations.
    It also shows where they actually wound up regardless of where they were bought :)
    It covers all 2004 through early 2006 cars. It's in PDF format and I can't figure out how to copy it here, but it's on Page 3.
    Going down, transcribing - (Anyone want to calculate by Population Density?)
    State #
    CA 49640
    VA 7906
    FL 7470
    NY 7039
    WA 6859
    TX 6673
    PA 5893
    IL 5658
    MA 5366
    MD 5111
    OR 4355
    NJ 3979
    CO 3976
    NC 3678
    AZ 3602
    OH 3532
    WI 3011
    MI 2736
    MN 2577
    GA 2294
    CT 2255
    IN 2008
    MO 1680
    TN 1526
    NV 1473
    NM 1355
    NH 1238
    UT 1167
    ME 1157
    AL 971
    KY 960
    IA 930
    SC 926
    KS 870
    LA 854
    OK 755
    RI 727
    ID 694
    AR 685
    VT 679
    DC 615
    DE 584
    WV 576
    MT 525
    NE 453
    MS 410
    WY 312
    AK 219
    SD 208
    ND 117
  2. KMO
    KMO Senior Member
    1,889
    645
    Finland
    2023 Prius Prime
    Yuck, can't figure out how to format this properly, but here you go. Population figures are the 2005 estimate from the U.S. Census Bureau.
    Code:
    State    Prius        Population    Prius per 1000 people
    CA    49,640        36,132,147        1.37
    OR     4,355         3,641,056        1.20
    DC       615           550,521        1.12
    WA     6,859         6,287,759        1.09
    VT       679           623,050        1.09
    VA     7,906         7,567,465        1.04
    NH     1,238         1,309,940        0.95
    MD     5,111         5,600,388        0.91
    ME     1,157         1,321,505        0.88
    CO     3,976         4,665,177        0.85
    MA     5,366         6,398,743        0.84
    NM     1,355         1,928,384        0.70
    DE       584           843,524        0.69
    RI       727         1,076,189        0.68
    CT     2,255         3,510,297        0.64
    WY       312           509,294        0.61
    NV     1,473         2,414,807        0.61
    AZ     3,602         5,939,292        0.61
    MT       525           935,670        0.56
    WI     3,011         5,536,201        0.54
    MN     2,577         5,132,799        0.50
    ID       694         1,429,096        0.49
    PA     5,893        12,429,616        0.47
    UT     1,167         2,469,585        0.47
    NJ     3,979         8,717,925        0.46
    IL     5,658        12,763,371        0.44
    NC     3,678         8,683,242        0.42
    FL     7,470        17,789,864        0.42
    NY     7,039        19,254,630        0.37
    AK       219           663,661        0.33
    IN     2,008         6,271,973        0.32
    WV       576         1,816,856        0.32
    KS       870         2,744,687        0.32
    IA       930         2,966,334        0.31
    OH     3,532        11,464,042        0.31
    TX     6,673        22,859,968        0.29
    MO     1,680         5,800,310        0.29
    MI     2,736        10,120,860        0.27
    SD       208           775,933        0.27
    NE       453         1,758,787        0.26
    TN     1,526         5,962,959        0.26
    GA     2,294         9,072,576        0.25
    AR       685         2,779,154        0.25
    KY       960         4,173,405        0.23
    SC       926         4,255,083        0.22
    AL       971         4,557,808        0.21
    OK       755         3,547,884        0.21
    LA       854         4,523,628        0.19
    ND       117           636,677        0.18
    MS       410         2,921,088        0.14
  3. Kross
    Kross New Member
    88
    Pittsbugh, PA
    <div class='quotetop'>QUOTE(Tempus @ Jun 15 2006, 09:07 AM) [snapback]271583[/snapback]</div>
    Wow, Pennyslvania is among the top ten. I would never have guessed that. Hurray for us! :)
  4. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    Yes and California the top- not a surprise. With the Carpool sticker and higher than other states gas prices,,,,By the way just had our 05 done yesterday...SSC 60C
  5. naterprius
    naterprius Senior Member
    1,843
    I'm convinced that most of the Prii in CO are in Boulder County. They are everywhere around me.
    Nate
  6. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Here's a graph, based on KMO's data.
  7. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Here's a quickie map-graphic. I chose to break the per-1000 ownership data into four groups: CA-MA, then NM-AZ, then MT-FL, then all the rest, which taper off smoothly without any noticeable breakpoints.
    Excuse the quality; I just snagged a US map from google images and slapped in four colors. Brightest (lightest) green is the highest ownership group, yellow is next, then dark green. Uncolored states are in the bottom group. (Some dark green states have speckling, but that was just an editing artifact.)
    There are a couple of points to remember when viewing a map like this, however: 1) The Midwest may still be a stronghold of American-car purchasers, so Toyota won't be well-represented there; 2) Though the data is normalized for state population, the sheer size of some states will over- or understate their importance in the image. (For example, Wyoming is a huge yellow slab, but its population is much lower than, say, New Jersey. Thus its large yellow color area overstates its "yellowness.")
  8. B Rad
    B Rad New Member
    295
    <div class='quotetop'>QUOTE(Rick Auricchio @ Jun 15 2006, 03:42 PM) [snapback]271827[/snapback]</div>
    Now how about somebody checking to see who would win the next Presidentual race between the lt/dk green states and the white/yellow....Then send the results to both party headquarters and maybe we will get some much needed enviromental laws and incentives..
  9. kDB
    kDB New Member
    241
    Fenton, MO
    <div class='quotetop'>QUOTE(B Rad @ Jun 15 2006, 06:57 PM) [snapback]271883[/snapback]</div>
    it's the 2004 election, but it does give a good fit.
    http://www.electoral-vote.com/
    better maps, but harder to see how it fits, except maybe the last map.
    http://www-personal.umich.edu/~mejn/election/
