I bought a 2009 Prius with 230,000 Miles.
Discussion in 'Gen 2 Prius Main Forum' started by Simbaboy, Jan 4, 2017.
  1. Mendel Leisk
    40,457
    Be really careful to use nothing but the kosher TOYOTA ATF WS fluid in the transaxle. And, it very simple to do, but dealerships often have no experience with it, will fight you tooth and nail to not do it, and/or grossly overcharge for the service. Shop around.
    Also, no offense, but I would try to shake the notion of getting a "full service". Instead, have a read through the Toyota Maintenance Schedule, look up the car's service history, have it checked over if you want, and settle on specific things that warrant doing, a few at a time. Dealership will try to hard sell a lot of money makers that aren't needed, could even be detrimental.
    #41 Mendel Leisk, Jan 14, 2017
    Simbaboy likes this.
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Why do you say this? Because it's a "lifetime" fluid? I'm sure they would be capable of doing it if a customer requested it.
    So easy to do and one of the things I really liked about the eCVT. A non-hybrid CVT with a torque converter is much more expensive to do and may not be done correctly by some mechanics.
  3. Mendel Leisk
    40,457
    Priuschat member experiences mainly. Dealerships responses:
    1. It's "lifetime" fluid (as you say)
    2. It's very complex, requires techstream, specific temperatures, gonna cost you, and on and on. (I believe there's some other Toyota vehicle they're thinking of?)
    And yeah, I've done ours myself, 3 times now, simple and straighforward drain-and-fill. Comparable to doing an oil change.
    bisco and Raytheeagle like this.
  4. Simbaboy
    Simbaboy Active Member
    134
    112
    Mid-Michigan
    Thank you all.
    I do minor repair/maintenance on my own motorcycles/scooters but have always been very leery about going under a car.
    I will check the health of my 12V battery and replace it myself, if needed. So far it appears strong but I know this can go bad with minimal warning. I know my battery is at least 5 years old.
    I will order the ATF WS and washers (maybe the kit from Amazon) and see if a local mechanic will charge me $20-30 and change it for me.
    Thank you all,
    Simba
  5. Simbaboy
    134
    112
    Mid-Michigan
    Slowly, as I get into a ZEN mode, my MPGs have risen from 37.5 up to 42 MPG so far (140 Miles since reset).
    A car/key red light came on temporarily--I am assuming the key fob (smart key) battery needs replacement.
    Thank you all,
    Simba
    EDIT: Actually, I think it means the theft deterrent system is working. I had just no noticed this before.
    #45 Simbaboy, Jan 15, 2017
  6. bisco
    51,017
    sounds right.
  7. bwilson4web
    15,982
    Actually I use eBay completed sales for 'fair market' price. A 2010 with 56k went for $8.2k and a salvage title for $5.8k. CarMax offered $6.0k. Mine went for $8k with Garmin GPS and receiver hitch.
  8. Simbaboy
    134
    112
    Mid-Michigan
    I have had the 2009 Prius for about 2 weeks now.
    The Driver side power lock mechanism never worked so I started doing what the previous owner did--stop locking the car. It was too much pain to get in from the passenger side to open my door or take out the key from the 'smart fob'. I don't keep any valuables in the car. The previous owner said "you have to be really desperate to steal a Prius, especially one with 230,000 Miles'. Initially, I was offended but now I agree with him.
    A coworker who lives about a Mile from my home has a 2010 Prius (bought brand new) and we take the same route to work. He gets 58MPG in his 2010 Prius while I get about 42MPG in my 2009. He has had a lot more experience driving his car and I hope to emulate his driving and at least get 50MPG. I still use my Hummer H2 (9 MPG) when there is heavy snow on the ground--I can't afford to miss work. My coworker and I have a 100 Miles competition going when I have had more experience with my car. The MPG winner gets his latte paid for. I have a habit of filling my tank when it gets to just over half and may have to let it get to a 1/4 when the competition begins.
    I just ordered Toyota ATF WS from Amazon, washers and a 'hosed' funnel. I will take all to the oil change place and hopefully they will do a fluid change for me at the next oil change. I could (learn to) do it myself but its not for me.
    Overall, really liking the car a lot.
    Simba
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,136
    Tampa, FL
    Glad you're enjoying it. A couple ideas on the door lock:
    Any key maker can make a duplicate door key for you. I use one for my wife's car since she only has one fob. I programmed my fob to work in her ignition slot and use the key for the doors if I don't have her or her fob with me when I drive it.
    I said earlier that replacing the door lock motor is finicky. Don't let that scare you off. The only finicky part is making sure you get the shaft lined up with the hole it goes into. The rest is a piece of cake. You should be able to find a replacement on ebay. That's assuming it's the mechanism at fault and not the sensor.
  10. Simbaboy
    134
    112
    Mid-Michigan
    Jerry, I think its the actuator mechanism--As soon as I touch the driver's door I hear all the locks opening but the driver's side. Same thing with manual power lock from the inside.
    The mechanism itself is about $80 on ebay.
    Thank you,
    Simba
    #50 Simbaboy, Jan 19, 2017
    jerrymildred likes this.
  11. Simbaboy
    134
    112
    Mid-Michigan
    Checked the status of my 12V battery this morning after the car had been been sitting for several hours:
    it read: 12V
    Five minutes after load it read 11.6V and after Powering the car up it read 14.1V
    and then I decided to go on a city ride (waste a little gas and improve my Prius driving skill). It was only an 8 Mile ride but showed me the car will give me at least 50MPG come this Spring.
    Aaron Vitolins likes this.
  12. jerrymildred
    11,517
    14,136
    Tampa, FL
    That looks pretty good for what appears to be an ailing 12V battery. It still has some life left in it, but you should probably replace it soon. My last one actually got down to between 8-9 volts at rest. I'm surprised it would even turn on the computer.
  13. Moving Right Along
    Moving Right Along Senior Member
    699
    546
    My 3 year old 12v battery has similar charges. I think your battery is fine for now. If it gets below 12v unloaded, then I'd look into getting a replacement.
  14. Mendel Leisk
    40,457
    I never know how to respond to 12 volt readings taken thus. You've gotta check it with everything off, with a digital multimeter. Under the hood jump start point is fine.
  15. jerrymildred
    11,517
    14,136
    Tampa, FL
    Good point. That is the only way to really know how it is.
  16. Moving Right Along
    699
    546
    Why wouldn't the display reading be usable? I understand that there's more that the battery is powering if the screen is used, but it seems to me that could easily be accounted for, as it would be consistent between vehicles.
  17. Simbaboy
    134
    112
    Mid-Michigan
    Either way I am not having any symptoms of a weak or weakening battery so I might be ok for a bit. The battery is at least 5 yrs old so it will be replaced in a couple of months but no major rush.
    Thank You, Friends.
    #57 Simbaboy, Jan 19, 2017
  18. dolj
    dolj Senior Member
    8,182
    4,167
    Wellington, New Zealand
    If you want the true resting voltage then what Mendel says is true. However, it is not the most important reading when looking to see if the battery is usable. That voltage is the loaded voltage. For our purposes the MDF readings are fine, just not ideal. Using a voltmeter at the battery is the ideal.
    While this is not going to cause problems starting or using the car, it is technically flat. If you are interested at all in getting long life out of your current battery, it needs to be fully charged immediately. An OEM Prius AGM battery in good condition will charge up to 13.2 V and after resting should settle at 12.8-12.9 V. You either need to drive more or purchase a good automatic charger that has an AGM setting and use it regularly (fortnightly, monthly) depending on your driving patterns. After charging and sitting (min 2 hours), the voltage at which it settles (i. e. how far below 12.9 V) will give an indication of how far the battery is off from needing to be replaced.
    In a way these batteries are very forgiving, given their small size, as they do not have to do any heavy lifting, unlike regular car batteries that have to crank the starter motor.
    Watch out for the tell tale sign of impending demise of the 12 V battery, the momentary flash of the master caution light (aka the triangle of doom). This is the only warning light that does not light in the start up self test. The momentary flash is the low 12 V warning.
    #58 dolj, Jan 19, 2017
  19. Simbaboy
    134
    112
    Mid-Michigan
    Hello Mendel,
    Do you have a part # on the Canadian Tire Motomaster Battery (mentioned in another thread) that would work in a 2ndG Prius? Being in Michigan I travel frequently to Toronto and may pick one up.
    Thank you,
    Simba
  20. Mendel Leisk
    40,457
    I may be overthinking it, but as soon as you're using the car, turning it on, to analyze the battery, you're muddying the waters. How much is the battery loaded, and what's that doing to the voltage. It's like checking tire pressures while they're warmed up.
