Wireless Backup camera connection to the reverse wiring 2011 Prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Jean Stoffel, Jan 26, 2017.
  1. Jean Stoffel
    Jean Stoffel New Member
    Hi everyone, I purchased a Wireless Backup camera from Auto-Vox. It requires connection to the 12V power of the reverse wiring in my 2011 Prius. I am not sure which wire it is in the tail light (I took a pic). Has anyone done this? Please help me...
  2. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    The connector at the bottom is the reverse light. The white/black is (probably) negative, and you're looking for the positive which is (probably) the red/blue. I would tap in to the red/blue one.
    Jean Stoffel likes this.
  3. saltdiscus
    saltdiscus Member
    198
    89
    US
    You can do this 2 ways since I recently installed backup camera.One is to tap wire from driver side below the dash.pin 29 red wire which I found easy.Second is tap the red/blue for 12volt and any metal like screws for ground.
    Checkout the youtube video.
  4. Jean Stoffel
    Thank you guys.
  5. neojohncarter
    neojohncarter New Member
    New Jersey
    When you say, tap.. is it by scotch lock or by any other means? I am also looking to install a wireless backup camera on my 2011 prius II.
  6. Dylan Doxey
    1,389
    3,459
    92
    There are many ways to do it. A clean and simple way is to use a t-tap connector like this.
