Record your Prime and Gas Fill-ups
Discussion in 'Prime Fuel Economy & EV Range' started by ukr2, Jan 28, 2017.
  1. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    As we did with the PIPs, who has a Prime and Record your Gas Fill-Ups.
  2. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    how do I type in my info
    priuscatprimeguy likes this.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    DITTO
    thatoneraccoon likes this.
  4. Mendel Leisk
    41,330
    Yeah, I tried too, just out of curiousity, something needs fixing. Couple more thoughts, regarding making the data more international:
    1. Date format: stick with yyyy/mm/dd? The US convention of mm/dd/yyyy is not universally understood, can be confusing.
    2. Identify location so that anyone around the world can understand? "Victor, NY" is understandable in US, but it's a big world.
    MichinZen, mountaineer and bisco like this.
  5. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Try again
  6. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Try again
  7. thatoneraccoon
    201
    146
    Ohio
    it worked :D thanks
  8. priuscatprimeguy
    2,730
    2,640
    IT'S WORKING NOW, THANKS:D
  9. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    So far 5 Primes recorded. I know there are more on PriusChat. I counted at least 6 in some threads.
    Please add yourselves.
  10. Fattypanda
    Fattypanda New Member
    Mckinleyville, CA
    Ok, how do I add my info.?
  11. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    It's a Spreadsheet. Just select the box below the last member and enter your info for each column.
    Son of Gloin and thatoneraccoon like this.
  12. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    OK, besides the 5 that have Recorded and Fattypanda, I come across 16 other Prime owners.
    Please Record your info above. Thanks.
  13. bwilson4web
    16,193
    When you finally get around to it, be sure and update the www.fueleconomy.gov web site for owner MPG.
    Note that I've put in two, gas-only, entries. The EPA has pointed out they have no way to record electrical charge kWh which is OK for me. Both of my entries were gas-only.
    barbaram and thatoneraccoon like this.
  14. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Bob,
    I charged my old Prius and now my new Prime at Home and at work, 15 miles away.
    I have a P3 International Kill A Watt at both locations, recording the daily kwh and totaling them every Gas Fillup.
    The Spreadsheet for the old Prius listed 57 members recording 433 Gas Fillups.
    15 members had 10 or more entries. I had 80 entries in 5 years.
    We summed and averaged everything.
    Check it out -
    We could do the same for the Prime in this thread's spreadsheet.
    I hope to find all the Energy Monitor items before my fillup...
  15. ttait
    ttait Active Member
    273
    163
    Southern California
    Is there something like a 240V Kill A Watt? Plug and play would be very nice.
  16. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    ttait, Write them and see.
  17. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Looking at the O/M it seems there is no one screen like the PiP EV ratio summary.
    Also, one owner reported somewhere (was it inferno?) that Prime computer calculates EV miles differently than PiP. While PiP registers EV miles by the mode (miles with no ICE in HV mode are HV miles), Prime registers these as EV miles. Worth verifying. If this is the case then I think you will not find HV miles at all in the Prime's displays, registering miles with no ICE in HV mode as EV miles will result poor HV only mpg.
    #17 giora, Feb 1, 2017
  18. bisco
    51,843
    i hope that is not the case, it makes little sense. there wouldn't even be a way to calculate at the pump.
  19. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    OK, I've seen 34 Prime members and only 12 have Recorded their info in the spreadsheet, so far.
    Please add you Prime.
  20. pjbtk
    pjbtk New Member
    Washington, DC
    Just added my prime :)
    bisco and thatoneraccoon like this.
