2013 Prius v (lowercase v for the Prius v wagon) won't start after front brake pad replacement
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by adammharvey, Jan 31, 2017.
  1. adammharvey
    adammharvey New Member
    Tampa, FL
    2013 Prius v wagon
    I replaced my front pads and disconnected the negative cable from the 12v. I reconnected the 12v and the car turns on but the engine does not turn on. I see a lot of tutorials on how to put any prius into maintenance mode on the screen but I am unable to find a tutorial for a 2013 prius v (lowercase v for the Prius v wagon).
  2. Mendel Leisk
    41,341
    You're thinking with maintenance mode to force the engine on? I do not know, that might be a wild goose chase, to cure a symptom.
    A puzzler..., try disconnecting the neg cable, wait a few minutes, reconnect, try start up again?
    Nothing else was done, say fuse pull, per gen 2??
  3. adammharvey
    Tampa, FL
    2013 Prius v wagon
    I didn't have a multimeter handy with me and I wanted to visually see the battery strength. I was able to get it into the correct mode to do so and the battery seems fine but the car will still not start correctly. When I have my foot on the brake and turn it on, I put the car into drive and it goes into neutral. After that it yells at me to put it back into park. I am unable to get this car to actually run.
    Mendel Leisk and iamvietdang like this.
  4. Air_Boss
    Air_Boss Senior Member
    4,190
    1,177
    New Yawk
    Just wondering; why disconnect the battery when changing front disc pads?
  5. adammharvey
    Tampa, FL
    2013 Prius v wagon
    From what I read, if you dont and by chance have your keyfob on you, it will compress the brake cylinders. which will screw up some things.
  6. Mendel Leisk
    41,341
    You may be ok as long as you don't open driver's door, start the brake pressurizing process. Personally, I figure belts-and-braces: I want to be real sure it doesn't happen: could pop out a piston when caliper is off the rotor. Disconnecting the 12 volt battery ensures nothing's going to happen, regardless what you do.
  7. rjparker
    10,101
    6,264
    Does it go to "Ready" after you start it? With error lights out?
  8. Air_Boss
    4,190
    1,177
    New Yawk
    Pressurizing the accumulator does not affect distribution line pressure.
  9. Mendel Leisk
    41,341
    When you replaced pads, did you pump brake pedal a few times before hooking the 12 volt up and attempting to start the car. I'm thinking if you didn't: maybe the car's detected excess brake pedal travel, and accordingly locking out Drive? No warning lights though??
    Grasping at straws though.
  10. adammharvey
    Tampa, FL
    2013 Prius v wagon
    When I replaced the pads, I connected everything gain, went to start the car but nothing happened. I realized I didnt connect the negative to the 12v. Once I connected the negatvie I pressed the brake and went to turn it on but the engine did not turn on. All lights turn on but the engine will not.
  11. rjparker
    10,101
    6,264
    Does it go to "Ready" with error lights out?
  12. adammharvey
    Tampa, FL
    2013 Prius v wagon
    No ready is shown
  13. rjparker
    10,101
    6,264
    No Ready means no engine or inverter control. I assume you have the triangle hybrid error light. The system will go into neutral without a Ready light to allow it to be pushed out of a parking spot.
    #13 rjparker, Jan 31, 2017
    Air_Boss likes this.
  14. adammharvey
    Tampa, FL
    2013 Prius v wagon
    I'm about to take my wheels off again and take a look because this seems like it might not be a battery issue since the 12v is doing its job.
  15. adammharvey
    Tampa, FL
    2013 Prius v wagon
  16. rjparker
    10,101
    6,264
    You indicate the 12v is ok but maybe it isn't. I would put a charger on it or use one of the jump start boxes (extremely carefully) to ensure the battery is not low. That can cause a failure to achieve Ready state. Maybe you ran it down with doors open at some point.
  17. adammharvey
    Tampa, FL
    2013 Prius v wagon
    I took a read of it and it states 12v but it drops when anything the car does, down to 11.6-11.4.
  18. Mendel Leisk
    41,341
    12.0? How are you measuring this, with a digital volt meter, with the car shut down? That's not very good btw, near toasted. You should do a charging session if that's the case.
  19. rjparker
    10,101
    6,264
  20. adammharvey
    Tampa, FL
    2013 Prius v wagon
    I went through the cars system display option. press button without foot on brake, hold the car button, while turning the lights on and off three times. After the third time lift finger from button and then your in. From there it shows you the voltage that the battery is pushing out.
    CAITLIN FOLEY likes this.
