Prius Wheel Covers
Discussion in 'Gen 4 Prius Main Forum' started by JimmyPri, Feb 1, 2017.
  1. JimmyPri
    JimmyPri Active Member
    201
    245
    Hilo, Hawaii
    I had a problem when taking off the air valve cap and it dropping between the wheel cover and the brakes. The space for access to the valve is just too narrow. So I came up with this solution that I show in the video.
    Tariq87, kithmo, Mendel Leisk and 4 others like this.
  2. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    Good idea...
  3. JimmyPri
    201
    245
    Hilo, Hawaii
    Thanks SAMPROCAT
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Good idea - though why they didn't install longer valve stems in the first place. On 2 of my last 3 cars, when it came time to replace tyres, I said "LONG STEMS please". Made it much easier.
    RCO likes this.
  5. Bluegrassman
    Bluegrassman Active Member
    229
    185
    US
    Great idea Jimmy! I guess they assume nobody checks their own tire pressure anymore. Has anyone tried the extenders? I used some similar to this on another vehicle years ago. They worked fine. Once it came time to change tires I asked for longer stems
    Edit: for the life of me, I can't get a link to post. Argh!!!!!
    Just search "valve stem extenders" on Amazon or wherever you prefer to shop
    #5 Bluegrassman, Feb 1, 2017
    alanclarkeau likes this.
  6. JimmyPri
    201
    245
    Hilo, Hawaii
    Thanks alanclarkeau, I think I will do the same with longer valve stems when I need to replace the tires.
  7. JimmyPri
    201
    245
    Hilo, Hawaii
    Thanks Bluegrassman on all my past cars I never checked air pressure as often as I do now on the Prius. My next set of tires when I need them will have longer valve stems.
    Bluegrassman likes this.
  8. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    Forward the video to about 2:20 for the fix and demo. Great idea as well. I lost one of mine so I definitely appreciate the video
    RCO likes this.
  9. JimmyPri
    201
    245
    Hilo, Hawaii
    Thanks robsnyder20 and thanks for watching.
  10. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    Great tip. I had the same issue the very first time I inflated the tires at the gas station - I couldn't get the air valve cap out of the narrow space between the plastic cover and the alloy wheel it was stuck into. I had to roll the car forward a bit to get it land on the floor.
    Ever since, I take extra care when inflating the tires... :)
    A better design that does not allow the valve caps to fall into small inaccessible spaces between the plastic inserts and the alloy wheel would be a welcome change.
    alanclarkeau and RCO like this.
  11. Samprocat
    491
    297
    Lincoln, NE
    Reason why not is rotating forces .....
    If it's any longer it will leak .....
  12. JimmyPri
    201
    245
    Hilo, Hawaii
    Thanks for your comment pakitt.
  13. JimmyPri
    201
    245
    Hilo, Hawaii
    Good point SAMPROCAT. It would catch the wind more and probably vibrate?
  14. Samprocat
    491
    297
    Lincoln, NE
    Only steam valves that will work longer than factory are one with rubber and metal design like some expensive cars have.....
  15. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Good Idea Jimmy, I just love these handy tip videos.
    Can you even get longer TPMS valve stems ?
    I used to use a piece of rubber fuel tubing to take caps off valves that were awkward to get at. Loosen the cap by hand, stick the tubing on it and screw it off. To put it back, screw the cap on pull off the tube and finish tighten by hand.
    RCO likes this.
  16. JimmyPri
    201
    245
    Hilo, Hawaii
    Great idea kithmo, I was thinking there should be a tool to do that. Your idea is the perfect tool.
  17. alanclarkeau
    7,045
    7,592
    I didn't consider TPMS - for some reason, TOYOTA didn't offer it here in Australia, even as an option.
    Prodigyplace likes this.
  18. ETP
    2,802
    1,170
    Auburdale FL
    Exactly, these have the built in electronics so how do you put in longer valve stems?
    I trade cars when the valve stems need replaced. ARGH!
    RCO and alanclarkeau like this.
  19. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    Great video. Gave me a good laugh and a good idea to avoiding dropping the cap.
  20. JimmyPri
    201
    245
    Hilo, Hawaii
    Thanks Neohippy for the comment and for watching.
