Record your Prime and Gas Fill-ups
Discussion in 'Prime Fuel Economy & EV Range' started by ukr2, Jan 28, 2017.
  1. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    pjbtk,
    Thanks for adding your info. However, someone moved the Freeze Row and when I corrected it, you line disappeared.
    Can you add yourself again. Thanks.
  2. mozdzen
    mozdzen Active Member
    719
    295
    Phoenix
    2015 Tesla Model S
  3. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Have a look at the sticky in the Gen1 Prius plug-in forum and you will see this one can develop to database Fuelly can't match.
  4. bwilson4web
    15,929
    The only problem is our cars do not record the charge and over half of the free chargers have no meters ... they blind headed. So unless someone spends extra money to track the charging, we're all pretty much SOL for kWh. With one exception.
    I am running a week on just EV using a combination of home and free chargers. This means at the end of the week I can report the miles EV and 'reverse engineer' the kWh. It is by no means precise but 'close enough' for our purposes.
    Son of Gloin likes this.
  5. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Yes, with the PiP we have 'EV Ratio' summary display (giving EV miles and kWh, HV miles and gasoline gallons - since reset. It seems this is missing with the Prime. Add to this the fact that miles with no ICE in HV mode are tracked down as EV miles...plus possible 'charge mode' adding more...it seems Toyota wants owners to look at 'raw' mpg, period!?
  6. bisco
    50,801
    bad pub for toy, makes no sense. not gonna come close to the epa. i wonder if someone had a 'senior moment'.
    mozdzen likes this.
  7. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    Thanks for the nice comment, giora.
    giora likes this.
  8. RJ Primw
    RJ Primw Member
    65
    87
    South Jersey
    Wonder how long that site with be up.
  9. techumper
    techumper Junior Member
    Hanford, CA
    No clue how to adjust the data in the cells I inputted to be centered like the rest, so my apologies. Also on the second tab does the Miles column equal odometer miles or miles traveled on a tank? Thanks..
    pjbtk likes this.
  10. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    For Fillups, enter the Miles since the last Fillup.
  11. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    OK, I've counted at least 70 Primes on PriusChat, but only 17 Recorded above.
    Please add your info.
  12. geguia
    geguia Active Member
    210
    108
    los angeles
    i use fuelly - anyway to share that data?
    im average 119 mpg per tank
    Graz likes this.
  13. jerrymildred
    jerrymildred Senior Member
    11,517
    14,135
    Tampa, FL
    In your fuelly stat page, below the logbook, there are some links. Bottom center one says, "badges." Click that and it will give you several options that you might want to use in your signature here.
    Edit to add: The only drawback with fuelly is that they don't have a way to account for electricity.
  14. Mendel Leisk
    40,233
    Yeah. It's been a while since I did it, but Fuelly provides a couple of bits of code that you can put in your signature here. It takes longer to figure out how to do it here I found; just keep plugging away at every one of your personal links, sooner or later you'll get it. Then, they see your fuelly average, and it's a link too I believe: clicking on it they see your public page at fuelly.
  15. jerrymildred
    11,517
    14,135
    Tampa, FL
    Good point, @Mendel Leisk . I forgot to mention that it is a bit of a pain in the patootie. But trial and error should eventually pay off.
  16. bwilson4web
    15,929
    Not quite sure how to handle seven days of pure EV so I took a swag:
    • tripmeter showed 301 miles
    • used EPA "25 kWh per 100 miles"
    • 3 * 25 ~= 75 kWh
    I'm open to suggestions. To avoid a divide by zero, I used a very, very small amount of gas.
    jerrymildred likes this.
  17. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    Bob and ALL,
    Did you get gas? Record your Fill-ups ONLY when you fill up the tank.
    bwilson4web likes this.
  18. bwilson4web
    15,929
    Okay ... I'll top it off; reset trip meter; burn warm-up, and; another week of EV. Then I'll top it off. Any guess of what it'll be.
  19. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    I wouldn't bother going to fillup unless you need to. Just to top off isn't necessary.
  20. geguia
    210
    108
    los angeles
    thanks - just updated my sig with fuelly - it's nice to see how much we are saving over our previous gas guzzlers
